running into problem while driving..
Old Mar 10, 2008 | 06:20 PM
live_again_integra's Avatar
Default running into problem while driving..
ok ~ i was driving on the free way.. just sudden rpm drop.. to 3-4000... so pull over check for problem ... sensor broken under the distibutor ??? what sensor?? any one????? and can it cost problem like that .. i have to drive the car around 3000 rpm ... and everything seem just fine '~
Modified by live_again_integra at 7:42 PM 3/10/2008
Old Mar 10, 2008 | 07:44 PM
96integralsvtec's Avatar
Default Re: running into problem while driving.. (live_again_integra)
knock sensor????? idk ks would be my guess.
Old Mar 10, 2008 | 08:03 PM
GiT LaO'd's Avatar
LOL...THAT IS NOT THE KNOCK SENSOR FOR SURE...
Old Mar 10, 2008 | 08:10 PM
Default Re: (GiT LaO'd)
lol i didnt even see the second pic till now i thought it was on the back of the block my bad i have no clue
Old Mar 10, 2008 | 08:33 PM
HONDACURA-DB8's Avatar
Default Re: (96integralsvtec)
37870-PJ7-003 SENSOR ASSY., TW (Circled in red)
Old Mar 10, 2008 | 08:54 PM
what sensor is that ~ did a little search on the manual ..no luck i hate honda manual ~
Old Mar 10, 2008 | 09:58 PM
XSIintegra's Avatar
I believe that is a water temp sensor.
Old Mar 11, 2008 | 02:20 PM
Default Re: running into problem while driving.. (XSIintegra)
just replace that ... but doesnt seem to fix the problem ~ what give ~ ????
Old Mar 11, 2008 | 02:44 PM
B18CivicHatch's Avatar
it looks like your engine coolant temperature sensor i had mine break in my car and it acted funny while i was driving right around the 3k mark and then i replaced it and its been running like it should be that happened to me three months ago so if it is the ect sensor you'll need a 19 mm deep socket to get it out and when you put it back in get some high pressure and high temp locktight and dont over tighten it or it'll snap lol but if it is your ect sensor thats how ya gotta fix it it cost me 28.99 for it at autozone
Old Mar 11, 2008 | 03:01 PM
XSIintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by live_again_integra &raquo;</TD></TR><TR><TD CLASS="quote">just replace that ... but doesnt seem to fix the problem ~ what give ~ ???? </TD></TR></TABLE>
Sounds like you have another problem. There is a good chance that the sensor was broken before your other problem surfaced.
What is the car doing now?
Old Mar 11, 2008 | 10:35 PM
Default Re: running into problem while driving.. (B18CivicHatch)
ok ~ i took a little video of how it stuck on 3k rpm ~
http://www.youtube.com/watch?v=tb-eA6mHtQg
B18CivicHatch is that how your car run ?? before you have you ect sensor replace ???~ cause i replaced my with the one from my old engine ~
Modified by live_again_integra at 12:18 AM 3/12/2008
Old Mar 12, 2008 | 03:37 PM
rebar71's Avatar
Ummm - have you thought about finding out what code the CEL is throwing?
Old Mar 12, 2008 | 11:14 PM
Default Re: running into problem while driving.. (rebar71)
lol no code reader
Old Mar 12, 2008 | 11:20 PM
shake_em's Avatar
you dont need a code reader just do a search on how to check you codes all you need is a wire
Old Mar 13, 2008 | 03:14 PM
my car never did that it seems like your in limp mode try and figure out what code that cel is throwin you cuz it reved past 3k when it wasnt on but as soon as it came on the car didnt go past 3k so i bet it definately has something to do with the cel is it obd1 or 2?
Old Mar 13, 2008 | 04:09 PM
ok, my car was a 01 gs ~ .. but been striped. so now it have a 94 ls in it .. with obd1 ecu with jumper harness ...
i was replacing the coolant sensor with a old one i got from the junk yard.. and burned the ect sensor plug, then i replace the plug and sensor same thing happen the only thing different now is that the car doesnt start any more ~ what could be wrong .. ecu ? distibutor .?? ?? engine harness ?? i checked . no spark and no fuel !~~~
Old Mar 17, 2008 | 02:32 AM
any one ?? ?~~!
Old Mar 17, 2008 | 09:34 AM
steveo135's Avatar
This is a DIY on how to get CEL and ABS trouble codes, no reader required...
https://honda-tech.com/zerothread?id=978933
get your code(s) and report back
Old Mar 19, 2008 | 10:12 AM
Default Re: running into problem while driving.. (steveo135)
ok i think i got a few code ~~ but it all from the abs light ..
took video of it ,i uploading it right now , ,,, will be posted shortly ...
th code are
38 - solenoid (short to body ground/short to wire) RL-OUT
63 - Secondary oxygen sensor
81 - central processing unti (CPU
Modified by live_again_integra at 11:55 AM 3/19/2008
Modified by live_again_integra at 11:59 AM 3/19/2008
Old Mar 19, 2008 | 12:56 PM
mpls's Avatar
100% is your dizzy.replace it and i bet you it's gonna rum like a champ agian.and you can thank me later
Old Mar 19, 2008 | 01:50 PM
Default Re: running into problem while driving.. (mpls)
so the distibutor will cause no fuel ?? ?
and what about all those code ~
Old Mar 19, 2008 | 02:41 PM
steveharrmr23's Avatar
the fack that you got the second o2 code tells me that the ecu is wrong for an obd1 wiring harness because obd1 only have one o2 sensor so i would say that the ecu is an obd2 ecu not obd1 i would replace the ecu
Old Mar 19, 2008 | 02:51 PM
Default Re: running into problem while driving.. (steveharrmr23)
but car was running fine .. it just happem recently ,.. and i did the swap myself .. both engine and ecu is from a 94 integra ls .. 4 dr i pull it out myself ~ and ,,, is obd2 and obd1 ecu plug are different .. that the reason why i have my jumper harness ~ . .. thanks for all the reply ~ but i still dont sure what wrong with my car ~
Old Mar 20, 2008 | 11:46 AM
any one ??? ~!
Old Mar 23, 2008 | 09:23 PM
check those codes again then
b16a3delsol
14
Nov 4, 2007 06:51 PM
but
Sep 29, 2006 05:22 AM
Blind762
May 1, 2006 02:39 AM
SNsLude
May 17, 2005 08:41 PM
tysir
Jul 31, 2001 06:52 PM
