NGK Spark Plug Wires?
Old May 4, 2002 | 11:33 PM
turbo Si's Avatar
Default NGK Spark Plug Wires?
Does anyone here use the blue NGK 8mm spark wires on their turbo setup? If so, how are they working out for you?
Old May 4, 2002 | 11:42 PM
JDM EX's Avatar
Default Re: NGK Spark Plug Wires? (turbo Si)
Which parts of Texas you from.. Im from SA.. SO I use 8 mm NGK wires right now because I use Onseka 10mm wires and it burn out.. SO the 8 mm wires is still working on turbo.. I was amazing about the different wires..
Old May 4, 2002 | 11:50 PM
turbocoupe's Avatar
Default Re: NGK Spark Plug Wires? (JDM EX)
The Alamo City baby. . . by the way I use Ractive 8.5mm wires.
[Modified by turbocoupe, 2:51 AM 5/5/2002]
Old May 5, 2002 | 12:23 AM
ExospeedAMcrx's Avatar
stock wires and NGK wires are good enough. Have seen 11 sec daily driven turbo cars run them all the time. numerous 10 sec turbo cars as well are still running NGK wires.
Wil
Old May 5, 2002 | 01:09 AM
ninesecrx's Avatar
Default Re: NGK Spark Plug Wires? (exospeedAMcrx)
I run the ngk wires on my 9 sec car...They are the only wire to go with in my opion. We have tested other name brand wires and there has been misses and I have seen horespower loss from others. The reason stock wires are so good, and yes...I had a set on my car when it was in the 10's is because NGK makes them...go figure.
Old May 5, 2002 | 01:30 AM
Giuseppe's Avatar
ive ran my car fine with them for months..
when i turbo i dont think i will have any problems.!
good luck
Old May 5, 2002 | 11:19 AM
turbo Si's Avatar
Default Re: NGK Spark Plug Wires? (ninesecrx)
That's good to hear. I was suprised when they came as 8mm and began to wonder if they would work as we'll as a set of 8.5mm Magnecore's. Nevertheless I am glad to hear everbody's responses.
Thank You! David!
Old May 5, 2002 | 11:25 AM
HipNot's Avatar
i use them,great fit and finish,use too have crane 10mm,they were garbage,i seen the NGKs on Rado's integra too, uses them if that means anything
Old May 5, 2002 | 12:15 PM
tonydatyga's Avatar
yup, they
Old May 5, 2002 | 12:56 PM
BoostinDC2's Avatar
Default Re: NGK Spark Plug Wires? (tonydatyga)
NGK or stock
Old May 5, 2002 | 12:58 PM
ion_four's Avatar
Default Re: NGK Spark Plug Wires? (BoostinDC2)
Where's a good place to get the NGK's? I think my stockers are as old as the car (pushing 100k)...
Old May 5, 2002 | 02:54 PM
turbo Si's Avatar
Default Re: NGK Spark Plug Wires? (ion_four)
Another good thing about them is there cheap. I paid only $43.00 for them!
95gsr916
Apr 2, 2012 09:50 PM
Inextricabledrvr
Jun 22, 2009 09:35 AM
BOOSTIN1
Jul 24, 2004 02:50 AM
