Compression-What's yours?
Old May 3, 2002 | 10:18 PM
sweettooth's Avatar
Default Compression-What's yours?
What compression are you guys using and what do you boost on the street? I have 93 oct. With 9.5 or 9.6, how much could I boost on the street with tuning?
Old May 3, 2002 | 10:47 PM
PureTeg420's Avatar
Default Re: Compression-What's yours? (sweettooth)
assuming your engine can handle it, and you have a good fuel system, I'd stick with around 15-18psi on pump gas with 9.6 compression to be safe. Ideal compression for a daily driven turbo honda is anywhere from 9-10
[Modified by PureTeg420, 11:49 PM 5/3/2002]
Old May 4, 2002 | 04:12 AM
boosted hybrid's Avatar
11:1, running 8lbs on the street, 12lbs at the track. Powerband from hell....
Old May 4, 2002 | 07:57 AM
M.A.R.C.'s Avatar
Default Re: Compression-What's yours? (boosted hybrid)
wow... 11:1 and 12psi? ****... thank the Lord for standalone's and good tuning
Old May 4, 2002 | 08:28 AM
PrecisionH23a's Avatar
im running 9:1 compression and around 12-15psi on the street. if you have an inline fuel pump and fmu you should run about 8psi safely, a little more with proper tuning, injectors, and possibly an afc.
Old May 4, 2002 | 08:57 AM
turboex's Avatar
8 to 1 here, wisecos baby
Old May 4, 2002 | 09:01 AM
Slick GS-R's Avatar
Default Re: Compression-What's yours? (turboex)
the 9.5:1 srp pistons are going in soon.......
Old May 4, 2002 | 09:13 AM
2K_TEG's Avatar
Default Re: Compression-What's yours? (Slick_GS-R)
I will be running an effective compression of 9.67548....to 1
monster_c
Apr 6, 2012 02:14 PM
Evolsport
Jul 17, 2009 12:44 PM
n1neb4ll
Oct 12, 2003 10:10 AM
gtconcepts
Dec 19, 2002 06:11 PM
eMoTiOn_EnGiNe
11
Aug 5, 2001 06:20 PM
