Which turbo kit should i go with?
Old May 5, 2002 | 03:38 PM
NickGSR's Avatar
Default Which turbo kit should i go with?
Boosting my 99 gsr... I can get the fmax kit for about $2800.
Which one should I go with?
Old May 5, 2002 | 03:40 PM
NickGSR's Avatar
Default Re: Which turbo kit should i go with? (NickGSR)
What are any known problems with the FMAX kit and why would you suggest NOT to get it if that's the case?
Old May 5, 2002 | 05:11 PM
SIK IN DA HED's Avatar
New User
the FMAX fuel setup sucks. you have more luck wit the fmu and inline fuel pump that comes with the DRAG and REVHARD turbo kits.
Old May 5, 2002 | 05:18 PM
jamal-188's Avatar
Default Re: Which turbo kit should i go with? (dlplayboy)
I agree better yet, go w/ a hondata or other standalone with whatever kit you buy!!!
Old May 5, 2002 | 05:59 PM
tonydatyga's Avatar
this is a drag owned forum, didn't you know? Seriously though, fmax's fuel solution is quite poor. The fmu, inline/intank setup works well enough for "standard" single digit boost. Of course everyone is going to tell you to go standalone and by all means do if you can.
Old May 5, 2002 | 09:27 PM
NickGSR's Avatar
Default Re: Which turbo kit should i go with? (tonydatyga)
So even if I go with a hondata is the drag still the kit to buy?
Old May 5, 2002 | 09:38 PM
NickGSR's Avatar
Also, how come I keep hearing bad things about drags quality.. "F-max quality vs. drag" and all that "inability to put on an air filter"??
Old May 5, 2002 | 10:34 PM
Spankee2K's Avatar
I love my RevHard
[Modified by PressurizedB18C5, 7:36 AM 5/6/2002]
[Modified by PressurizedB18C5, 7:54 AM 5/6/2002]
Old May 6, 2002 | 12:23 AM
turbopimp's Avatar
Ummm... think about it... do you really expect to hear good things about DRAG on the fmax website? Obviously not since they are gunning for DRAG. Who doesn't claim to have the best "quality"? Don't believe everything you hear or read on a website... Do some research and decide for yourself... BTW the DRAG 3 kit not only DOES come with an air filter, but also has smooth polished/chromed metal piping between the filter and turbo, not rough, black dryer duct like fmax. DRAG 3 also uses a bigger more efficient TO4E turbo and has a bigger downpipe (2.5" vs. 2.25"). The FMU and pump supplied in the DRAG 3 is adequate for the intended boost levels and will at least have all cylinders running evenly. The fmax fuel "solution" is shady... additional injectors feeding the TB can lead to the closer cylinder running rich while the furthest cylinder leans out. Now you know why the majority of turbo'd GSRs on this board are powered by DRAG 3...
Old May 6, 2002 | 03:54 AM
GruvyTune's Avatar
New User
Default Re: Which turbo kit should i go with? (turbopimp)
Once I got the intake tubing problems ironed out with FMAX I have been happy.
I went with a Hondata system. not with their MF2 and extra injectors. I had them make a system for me with a 2.5" downpipe and was still able to clear my a/c. My system runs extremely well. I would recommend it as long as you do it this way. If not and I had to do it all over again, I may have gone with the Drag or the Maxrev after seeing that one now.
Old May 6, 2002 | 01:19 PM
Ray's Avatar
Ray
New User
Default Re: Which turbo kit should i go with? (GruvyTune)
maxrev or piece together your own.
Old May 6, 2002 | 01:36 PM
supergreenNA1's Avatar
New User
which kit comes with a manifold that will never crack??
which kit comes with ic piping that actually fits??
which kit doesn't make you drive your car to a muffler shop after the install??
which kit gives you the option of running a closed loop wastegate??
which kit actually makes an attempt (although i'll admit not a good one) to give you more precise fuel management??
the answer?? fmax
if you're that concerned with one cylinder leaning out.. which would be the #1 cyl btw .. get the kit without the mf2 and get either a hondata or an fmu and pump.
the kids on this site amaze me sometimes.
btw.. how many hp do u suppose your smooth metal intake pipe gives u?
[Modified by supergreenSol, 2:39 PM 5/6/2002]
2k1 GSR
Jan 16, 2003 11:07 PM
snake01
Jul 24, 2002 09:34 PM
Mr. Softee
Jun 5, 2002 06:56 AM
pub
May 11, 2002 09:20 PM
AK94GSR
Apr 12, 2002 02:58 PM
