How much boost should i run with my setup? any help apriciated
car is 2000 civic ex
2000 Civic B16a2 Engine Swap
Bored 10 Over
Eagle Rods
Wiseco 8to1 Turbo Pistons
HKS SS Blow Off Valve
Nuformz Block Guard
Unorthadox UnderDrive Pullies
Turbonetics T3/4 Turbo Polished
Spearco Intercooler
Tial Wastegate
B&M FPR
Vortec BDFPR
BBK 255LPH Fuel Pump
hondata 2b
dsm injectors
Test Pipe
O2 Simulator
Poly motor mounts
Poly Shifter Mounts
Clutchnet Stage 2 Clutch
Greddy Evolution Exhaust
thanks for any input
Bored 10 Over
Eagle Rods
Nuformz Block Guard
Spearco Intercooler
Tial Wastegate
B&M FPR
Vortec BDFPR
hondata 2b
dsm injectors
Test Pipe
O2 Simulator
Poly motor mounts
Poly Shifter Mounts
Re: How much boost should i run with my setup? any help apriciated (turboex)
your not going too need the FMU with hondata. you can do 10-12 psi daily with no problems and probably 15psi at the track. you might even be able to go a little more but your tuning will have to be right on par.
New User
Uhhh, 8:1 compression will have 15 psi all day long and 20+psi at the track easily. The DSM's 450's will run out of steam before 20psi though.
Randy
Randy
turboex
08-29-2002 08:06 PM
