vacum lines
Old May 2, 2002 | 09:24 AM
Coldsi's Avatar
Default vacum lines
Has anyone had a problem with running more than one vaccum line from the FPR. I have three lines coming from a tee on the FPR. I heard that boost transitions could be slow with too many lines off of one source.
Old May 2, 2002 | 09:26 AM
rtype11's Avatar
Default Re: vacum lines (Coldsi)
make up a vaccuum block that feeds off the intake manifold and run separate lines
Old May 2, 2002 | 09:45 AM
Coldsi's Avatar
Default Re: vacum lines (rtype11)
So have you had any problems or is that just a suggestion?
Old May 2, 2002 | 10:30 AM
92JDMSiR's Avatar
right now I'm running my AEM FPR, FMU, boost gauge, and BOV of my FPR vacuum source. the only reason i did this is to see if everything works out ok because an ITR manifold has barely any vac sources. I DO NOT RECOMMEND THIS.
Old May 2, 2002 | 12:04 PM
rtype11's Avatar
I have no vaccum problems, my motor is strong, my buddy has a '85 GN and a really trick vaccuum block on the intake feeds everything separately with dedicated lines. you can even get a brass tee block for this.
Old May 2, 2002 | 01:53 PM
CovertFI's Avatar
i only had problems when i shared a buch of lines with my map sensor line.
EastCoastRust
Aug 11, 2014 11:06 AM
CRXREFIC
Dec 17, 2010 09:16 PM
acrocat
Jun 30, 2009 08:23 PM
Andrew 825SM
Oct 24, 2002 07:15 PM
SagaGSR
Sep 19, 2001 06:50 AM
