I just talked to Joe at Alaniz...questions
I just got off the phone with Joe of Alaniz cylinder heads and he was a very nice and inforative guy. Anyways, his advice shocked me. I told him about my plans for a high boost LS. He told me a few things about his shop then went into his recommendation:
Stock Cams (I was planning on using stock anyways)
Stock retainers
Stock outer springs
His higher pressure inner springs
His SS valves
Full port and polish as described on the website
Not matching head bore to block bore (84mm)
After he told me these things I told him I was thinking about some titanium retainers, and dual valve springs and he otld me to forget about those things because they wouldn't do anything helpful for me. He also said he could charge me an extra $125 and open up the bore on the cylinder head to 84mm but his experience has shown no reason to do so, and that Erick's All motor race car has not enlarged the cylinder head cumbustion chamer in this way.
Also, and this is what gets me the most, he told me I could rev to 9K rpms. I would not try that, but could I? My initial response in HELL NO, but word on the street is this guy knows his ****. What are your impressions on this?
Stock retainers
Stock outer springs
His SS valves
Smarter than you
Re: I just talked to Joe at Alaniz...questions (2K_TEG)
hummmm, this kinda relates to my LS cams question earlier that got such a good response (insert sarcasm).. my question here is, even if u can rev to 9k will the stock LS cams make power up there? w/ the headwork u will have!
how high are u planning on revving your motor? u r doing the block girdle I remember right?
oh, what size valves did he reccomend?
[Modified by DIRep972, 8:46 PM 5/3/2002]
New User
Re: I just talked to Joe at Alaniz...questions (int3gra)
I think if his stiffer inner springs will keep the valves under control, the cams won't be a problem. Cams will flatten out when you're running NA if they can't get enough air in at high RPM, but under forced induction they should be able to pull significantly higher.
Re: I just talked to Joe at Alaniz...questions (DIRep972)
I asked him if he ever comes on here and he said he does, so hopefully we will hear from Joe himself.
He said he has tested all this on the flowbench, so I have no reason to doubt it...just shocked me. He does all the head work for Erick's Racing and they are hella fast.
[Modified by DIRep972, 8:46 PM 5/3/2002][/QUOTE]
how much did he quote you?
$875 for the headwork
$14.50ea for SS valves
$80 for inner springs
He is the only person I will recommend for headwork. I have talked to numorous people about headwork and I have even asked them all the same questions. I truly got the answers I was looking for when I was talking to Joe. He is not only a good porter, but he does know his honda heads and has tried multiple combinations. What I like about him is that he is always up for educating his customers. Like I said in a previous tread it is not necessary to open up the combistion chamber. I have a 2000 b16a2 head and he did pretty much the same thing you described above. Trust me, you can't go wrong. I'm going to be revvvvvinn and putting the power down. I'll post my stuff as soon as I get my parts that I ordered to finish things up. Glad you talked to him.
[Modified by BodyKits NW, 1:30 PM 5/3/2002]
Re: I just talked to Joe at Alaniz...questions (BodyKits NW)
Does he do any work with B18A heads? because I see nothing on his site that supports this. I am looking for springs and retainers.
wow thanks for the info, I think that should settle that debate. Maybe you should call Portflow as well, see what they have to say about that
Re: I just talked to Joe at Alaniz...questions (LsTurbo91)
Trust me, I called them too and asked the question. I got a answer, but it was more like a generic answer. But there was no real answer, does that make sense lol.
Re: I just talked to Joe at Alaniz...questions (MIKES)
How bout the 9K redline?? Anyone know anything about that? Can a set of $80 inner springs raise my redline 2200 rpm? Thanks,
Yes, since your still gonna be running stock cams. Without any extra lift, you wont be putting near as much additional strain on the valvetrain then say if you were gonna run some crowers.
Just shows there is more than one way to get the job done.
I'm a little concerned about the stock retainers, however. If one were to break, say goodbye to the old LS.
Re: I just talked to Joe at Alaniz...questions (earl)
the flowbench can be deceiving though....if a porter hoggs out a passage and removes a lot of metal, of course the head will flow better....knowing what areas to port and how much material to remove for optimum performance is the deciding factor....and it looks like Joe Alaniz knows what he is doing
Re: I just talked to Joe at Alaniz...questions (Quaalude)
When i scrap some money together he will be getting my block too. You guys should of sent in your stuff when he first opened up shop he was giving some crazy discounts.
TypeR0207
02-20-2002 10:44 AM
