Tial wastegate install
Old May 1, 2002 | 06:20 PM
a z n t a k's Avatar
Default Tial wastegate install
how do i hook up the Tial wastegate? some one please help.
Thanks,
azntak
Old May 1, 2002 | 06:26 PM
Etylorcen's Avatar
Default Re: Tial wastegate install (aZn TaK)
Screw it onto the manifold.
Old May 1, 2002 | 06:57 PM
intekragsr's Avatar
Default Re: Tial wastegate install (Etylorcen)
and plug in the vacume line
Old May 1, 2002 | 07:15 PM
falcongsr's Avatar
What is this crap?
Default Re: Tial wastegate install (intekragsr)
and click your heels three times
Old May 1, 2002 | 07:19 PM
inspyral's Avatar
Default Re: Tial wastegate install (falconGSR)
there's no place like home
Old May 1, 2002 | 07:43 PM
93LSivic's Avatar
Default Re: Tial wastegate install (inspyral)
Bestiality is a crime. Get your cack out of Toto.
Old May 1, 2002 | 07:44 PM
intekragsr's Avatar
Default Re: Tial wastegate install (93LSivic)
beastiality is a crime?
Old May 1, 2002 | 08:04 PM
1337 Si's Avatar
One day Smoop came to me and said, Roy.....what goes with Gin. I said Snoop, Juice. Juice goes with Gin. And he said Yizzea.
Old May 1, 2002 | 08:10 PM
Etylorcen's Avatar
Default Re: Tial wastegate install (Boosted Ego)
Hahaha i remember that ****.
intekragsr's Avatar
sense it completly makes not to my simple mind at least
Old May 1, 2002 | 08:55 PM
How do i hook up the vacumm lines? where does the vacumms goto?
Old May 1, 2002 | 08:56 PM
2K_TEG's Avatar
what the last 10 posts didn't answer your question? J.k.
Old May 1, 2002 | 09:04 PM
intekragsr's Avatar
Default Re: Tial wastegate install (2K_TEG)
I hate to be plastering my picture all over this server, but look at mine and that should be all u need. Good luck. Its really easy.
BTW: did u read the instructions?
[Modified by intekragsr, 6:07 AM 5/2/2002]
Old May 1, 2002 | 09:11 PM
spy54's Avatar
Id' ate to have thsi guys engine... NOT lucky bastard lol
Old May 1, 2002 | 09:34 PM
maxim's Avatar
Default Re: Tial wastegate install (spy54)
Just make sure the metal ring that comes with the Tial is put in correctly. Basically you need to make sure the smaller side of the ring is pushed up against the very bottom of the Tial and is flush when you tighten it down to the mani.
1)If you are not using an electronic boost controller or a manual boost controller, you do not need to do anything to the top port, but leave it open. But the vac line should go from the side of the Tial to a vac source after the T/B(I used my fpr line).
2)If you have a manual boost controller, the same applies with the top port(keep it open) but instead you will have a vac line going from the side of the Tial to the mbc and then from the side of the mbc to a pressured source(preferrably to the fitting on the compressor side of the turbo).
3)If you have an electronic boost controller read the instructions carefully, can't help you there.
[Modified by maxim, 12:36 AM 5/2/2002]
Old May 1, 2002 | 10:23 PM
93LSivic's Avatar
Default Re: Tial wastegate install (maxim)
Ok, to add to this. I have a manual boost controller. The way I have my lines running is htis. Directly from the compressor housing on the turbo into the mbc into the side port of the wg.
I have no problems at all with this setup and dont have any kinds of boost spikes either.
You dont want the line coming from the tb. You want it to come from the turbo itself so that the wg gets the most accurate reading.
Old May 1, 2002 | 10:54 PM
intekragsr's Avatar
i would have tapped the line to the compressor housing but I had no hole there.
Old May 2, 2002 | 05:33 AM
maxim's Avatar
If you are referring the not having a boost controller situation, a vac source after the T/B is much better than having a line going to the compressor. I used to do that not to long ago and lost about 2psi because of the I/C. I was told this by many people on this board plus a turbo rebuild guy here in Houston that you should always have a line going to a source after the T/B if you are not using some kind of boost controller and to just plug the hole in the compressor(if applicable).
Old May 2, 2002 | 09:03 AM
93LSivic's Avatar
Hmm. I am gonna try that. To say the least, I never had it hooked up before in any other way--just directly from the turbo itself. I know the IC and piping will lose some of the boost if its not efficient.
Actually, to test the efficiency of the IC and piping couldnt you use that as a simple test. Just change the wg vacuum source from post throttle plate to directly at the compressor housing and monitor the boost gauge between the 2 changes? So basically having it hooked up my way --turbo housing-- I should be seeing less boost than if I had it hooked up to a manifold vacuum source.
Hmm, gonna go warm the car up and see what happens.
Old May 26, 2002 | 02:33 PM
SIK IN DA HED's Avatar
New User
i thought the best way to hook up the wastegate was to run a line from the side port to the turbo? you guys actually have it tapped into a vacuum hose from the intake manifold? whats the advantage of doing this?
Old May 26, 2002 | 04:48 PM
intekragsr's Avatar
Default Re: Tial wastegate install (dlplayboy)
i had it tapped to a vacume source because my compressor housing had no hole to tap it to. Now that I have my avcr, I tapped the intercooler piping for both lines
Old May 26, 2002 | 08:02 PM
saso
Guest
Posts: n/a
where did you get that intake? Who make it?
Old May 26, 2002 | 08:18 PM
turbopimp's Avatar
Default Re: Tial wastegate install (saso)
That whole set up is a DRAG 3 turbo kit. Nice install, Intekra... looks real clean...
Old Feb 13, 2004 | 07:48 PM
CaptainMorgan's Avatar
Default Re: Tial wastegate install (turbopimp)
i know this is an old post but what does the top port do anyways.
Old Feb 13, 2004 | 07:52 PM
Full-Race Henry's Avatar
Default Re: Tial wastegate install (doubler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubler &raquo;</TD></TR><TR><TD CLASS="quote">i know this is an old post but what does the top port do anyways.</TD></TR></TABLE>
you hook it up if you have a ebc.
