FMU Questions
Old May 5, 2002 | 02:22 PM
dc r-spec's Avatar
Default FMU Questions
Aight here goes got a 99 ls with revhard turbo, trying to get it running but problem, My vacuum line coming off the top of the fmu has a tripple T fitting on it, Would anyone know what these lines would run to. I'm thinking one is for the blowoff valve. Also the vacuum line between the intake manifold and FPR, is that were you T fit into or am i thinking completely wrong. Thanks
Old May 6, 2002 | 08:58 AM
dc r-spec's Avatar
Default Re: FMU Questions (dc r-spec)
To the Top
Old May 6, 2002 | 09:51 AM
BoostedSi's Avatar
Should be tee'ed into the vacuum lines in the manifold.
Old May 6, 2002 | 09:53 AM
sushibug's Avatar
Default Re: FMU Questions (BoostedSi)
i T into the vacuum line above the intake manifold. the triple T... lets see, theres the boost gauge, the BOV, the FMU, and the wastegate (dont know if you need to do this because your external.) right now i only have 3 Ts and i need one more.
Old May 6, 2002 | 01:47 PM
dc r-spec's Avatar
Default Re: FMU Questions (sushibug)
just to make sure, you guys are talking about the vacuum line between the FPR and the front of the intake manifold right??? thanks
Old May 6, 2002 | 01:48 PM
sushibug's Avatar
yes... the line on top of the FPR. the line under it is a fuel line that also goes into the FMU.
quicksol95
Sep 23, 2004 09:46 AM
Jstue
Dec 16, 2003 06:50 PM
Andrew 825SM
Oct 24, 2002 07:15 PM
TurboedGSR
Sep 2, 2002 09:50 AM
jwork101
Jul 3, 2002 05:38 PM
