turbo "accesories"
turbo "accesories"
I have been doing non-stop research on turbos... and have found that I like the Rev-Hard kit the most. I know that I will need other upgrades that do not come with the kit. The kit comes with:
Vortech blowoff valve
High Pressure blue silicon hose
High volume fuel pump, boost dependant fuel pressure regulator
2.25" Aluminized mandrel-bent intercooler piping
2.5" Downpipe
(-3) Stainless steel oil lines and fittings
Oil return line, high pressure fuel line
All necessary vacuum tees
All necessary vacuum lines
Stainless steel hose clamps
Rev Hard hybrid turbo
Tube steel exhaust manifold
Deltagate wategate (nine psi spring)
3-row polished intercooler
Please list other things that i need to make this a better set-up.
Thank You.
2.5" Downpipe
Thank You.
Re: turbo "accesories" (chusai)
hondata
Other considerations include:
Larger injectors
adjustable FPR
gauges (duh )
boost controller
timer
.. just to name a few
Re: turbo "accesories" (VTC_CiViC)
hondata
Larger injectors
adjustable FPR
gauges (duh )
boost controller
timer
Larger injectors
adjustable FPR
gauges (duh )
boost controller
timer
Make sure you have a good oil return line.
RPS turbo clutch
01-18-2005 12:36 AM
tegaholic
10-24-2002 09:23 PM
