Stalling and hesitation
Old May 5, 2002 | 08:47 PM
b18c1-ek's Avatar
Default Stalling and hesitation
While the LINK ECU is out, I've reinstalled the stock ECU on the B20VTEC turbo, using stock injectors to break-in the car (no boosting). Timing is set at ~10 degrees, and fuel pressure is at 40psi. There seems to be a hesitation when I stab the throttle in neutral from idle. Additionally, once the car is decelerating and is shifted to neutral at a stoplight, the engine stalls, 100% of the time. I've tried adjusting the idle mixture screw on the stock TB, but that doesn't seem to help at all. Any one have any ideas?
Thanks
Old May 5, 2002 | 09:35 PM
MiraiZ's Avatar
Default Re: Stalling and hesitation (b18c1-ek)
sounds like fuel problems...how did you disable the boost?
Old May 5, 2002 | 10:24 PM
b18c1-ek's Avatar
Default Re: Stalling and hesitation (MiraiZ)
turbo is still bolted on, no boosting with a verrry light right foot
Old May 5, 2002 | 10:43 PM
b18c1-ek's Avatar
i forgot to mention that I still have the resistor box in place for the injectors... nah, couldn't be......could it?
Old May 6, 2002 | 02:09 AM
MiraiZ's Avatar
hmm...hard to say...but I would suspect the resistor box with stock plugs before anything else....
Old May 8, 2002 | 11:42 AM
b18c1-ek's Avatar
turned out to be bad idle settings due to the LINK... I was messing around with the stock idle-stop screw, which I shouldn't have in the first place
a1320honda
Sep 6, 2007 12:55 PM
oneforce
May 23, 2007 05:38 PM
jfruauff
Apr 29, 2007 01:54 AM
RACEPAK
Nov 19, 2006 09:01 AM
Nite_2nr
Aug 21, 2006 08:43 PM
