B18B1 Stock Injectors...what are they good for?
What is the stock B18b1 injector size ? 220 cc?
I plan on running a VORTECH FMU 12:1 with a bosch fuel pump for my T25 turbo (DSM 2nd gen) with custom manifold and Starion FMIC.
What is the max boost I can run? 8/10 psi? And max whp I can expect?
What is the max fuel pressure before the injectors go static? (Start Sticking Open)
Re: B18B1 Stock Injectors...what are they good for? (turbalude)
Just like he said there good paper weights. for a b18b you can make about 190hp on them thats it. with an fmu i wouldnt go over 8 psi anyway if you chose that route. 12:1 fmu is raising your fuel pressure quite a bit at 8 psi and anything over that your just taxing out your fuel pump and going to lean the crap out of your engine
at the jetties fishin'
Re: B18B1 Stock Injectors...what are they good for? (Turbo-LS)
not to mention that with a 12:1 at 8psi, the rail pressure will be so stupidly high it will severely affect the injector spray pattern...
havok hybrid
09-23-2002 05:01 PM
