What cams on JRSC??
Old May 3, 2002 | 07:16 AM
metal-x's Avatar
Default What cams on JRSC??
on a JRSC
Old May 3, 2002 | 07:25 AM
schwett's Avatar
New User
Default Re: What cams on JRSC?? (metal-x)
the stock ones
Old May 3, 2002 | 07:27 AM
dustin's Avatar
You cannot put cams on the JRSC.
Old May 3, 2002 | 07:29 AM
schwett's Avatar
New User
Default Re: What cams on JRSC?? (dustin)
i hope he was referring to the motor it's attached to!
Old May 3, 2002 | 07:34 AM
metal-x's Avatar
Default Re: What cams on JRSC?? (schwett)
I meant not in the charger , to the car its on a 94 gsr
Old May 3, 2002 | 08:58 AM
BHSCGSR's Avatar
Use your factory intake cam and a CTR or ITR exhaust cam. Then get yourself a good set of gears and dail OUT some overlap.....You will pick up about 1psi from taking out some overlap and the CTR or ITR exhaust cam will help in getting all that extra spent mixture out........
Old May 3, 2002 | 10:21 AM
metal-x's Avatar
Default Re: What cams on JRSC?? (BHSCGSR)
I could use 1 psi
Old May 14, 2002 | 02:59 PM
jabroni95gsr's Avatar
so then would it be bad to run an itr intake cam with a stock gsr cam for a similar application?
whatVTEC
Jun 1, 2005 03:59 PM
cjDC2
Jun 28, 2003 09:17 AM
hXc-DC2
Mar 29, 2003 12:23 AM
SCsol
Jun 26, 2002 09:43 PM
Halo
Jun 23, 2001 01:16 PM
