How to hook up inline fuel pump?
Old May 2, 2002 | 11:04 PM
yellow blur's Avatar
Default How to hook up inline fuel pump?
Hey guys, I was just looking over the last little things for my setup and I was wondering, how would I wire up the pump so that it gets power...
Here's a picture.
It's going on an 00 ITR where would I source power etc... thanks.
Old May 2, 2002 | 11:21 PM
intekragsr's Avatar
Default Re: How to hook up inline fuel pump? (yellow blur)
first, run the ground wire to the chasis, then run the positive wire through the firewall, under the dash and splice it into pin 4 or 7 of the fuel pump relay. It should be a grey box somewhere under the drivers side dash. Turn your key to the on position and listen to the fuel pump. It should buzz for 1 or 2 secconds and shut off. If not, you spliced it wrong.
Then cut the fuel line 2 inches from the fuel filter, extend it a little with some extra fuel line and hose barb, and put it into the part where there is no hose in the picture you posted. Then hook up the other hose coming out of the fuel pump to the other end of the stock fuel hose coming from the stock fuel rail.
BTW, how did you get a chromed out dumptube??? I got an ugly dump tube with my kit
Hope this helps
Old May 2, 2002 | 11:25 PM
Default Re: How to hook up inline fuel pump? (intekragsr)
I'm blingin all over baby! My compressor housing is chromed out too. Thanks for the directions man.
About the dumptube, what's funny is that when i was cleaning it up, some of the chroming cracked off on the underside where you can't see it. So much for that...
Old May 2, 2002 | 11:33 PM
intekragsr's Avatar
hehe ok, well have fun
Old May 2, 2002 | 11:37 PM
bigTom's Avatar
u chromed it? i hoped u realized chrome wont last before u did it
Old May 2, 2002 | 11:39 PM
Default Re: How to hook up inline fuel pump? (ek9t)
Well I didn't chrome it, now that I think about it, it's not chromed but polished. I got the kit used, and it came all polished. I lucked out I guess.
intekragsr's Avatar
lol, i skipped the part about where you chromed your compressor housing. U shoulda juss polished that it to a mirror finish, but chrome i dont believe has good heat properties( i pulled that fact outta my *** but I think its true)
Old May 2, 2002 | 11:40 PM
intekragsr's Avatar
ok, you posted before I read, polish is a good thing
Old May 2, 2002 | 11:43 PM
haha
Kward03
Jul 25, 2018 12:51 PM
DC_andrew
Jul 11, 2004 07:57 PM
TORQUE MONSTER
Aug 15, 2002 05:15 AM
Jamison
Jul 11, 2002 12:07 PM
