baffles in stock oil pan
I've taken my car out for about three days and totalled about 2 miles on it. happiest 2 miles of my life. but the fricken oil drain is leaking. at first I thought it was that the return had a slight kink in it and it was a 90 degree bend. ok fixed that no more kink and a slope into the pan. let tehe car warm up and no leaks. took it for another mile or so and looked under the car and BAM another fricken leak fromthe drain. the oil pan is tapped in the shallow portion of the pan. do you guys think it is the baffle in the pan causing this leak. I can't think of anything else. the hose is good as far as routing and there are no holes in it. I need help, I don't want to blow the seals on the frincken turbo too
Re: baffles in stock oil pan (92JDMSiR)
shallow part is bad as oil slops there and is close to DP, also recheck the weld on the fitting and re do your fittings with teflon sealant. check that drain is well sealed in CHRA.
Whatever
03-18-2009 06:16 AM
