Ran my car- awesome results!
This was the 1st time my new car has been run. I just wanted too see what it would do. Here is the best run:
60' = 2.175
330' = 5.824
1/8 = 8.829
MPH = 81.94
1000' = 11.446
1/4 = 13.681
MPH = 100.27
We pulled several 2.1 sec 60fts. The 1st run and worst launch of 2.338 resulted in a 13.922 @ 102.45 mph!
On the run that I totally missed 4th gear it ran a 14.029 @ 96.49 mph.
Here is my setup:
Car: '92 Civic VX hatch- gutted, drivers seat only, CF hood. 1990 lbs.
Engine: D16A JDM SOHC VTEC ZC- stock.
Turbo: GReddy TD04-15g with small greddy intercooler, 5 psi of boost, no cat, 2 1/4" exhaust w/a resonator dumping under the car.
Polyurethane mount inserts, Z10 radius arms, stock shocks, Tenzo-R 2 1/4" springs.
It was about 55 degrees out, and I ran the stock 14" steelies with the stock 7 year old 185/60-14 bridgstones. Tire pressure was 17 psi.
Waht do you guys think? I am extremely pleased and plan on going again on friday to try and better my times. I love my turbo SOHC!
[Modified by JFK78, 7:00 AM 5/2/2002]
60' = 2.175
330' = 5.824
1/8 = 8.829
MPH = 81.94
1000' = 11.446
1/4 = 13.681
MPH = 100.27
Here is my setup:
New User
Re: Ran my car- awesome results! (JFK78)
wow thats great
i bet having your car weigh only 1990 lbs had alot to do with those times
anyhow good job
i would love to see a dyno chart if you have one
anyhow good job
Re: Ran my car- awesome results! (RoaringTurtle)
It dyno'd at 166.1 hp and 147.6 tq at 5 psi. If someone could host/post the pic for me I could scan the dyno and my timeslip.
WOW, those are some excellent times. Good job. I was expecting to see a dohc in a little heavier car--but damn. Good job!! I cant wait to see what my times are like.
BTW, I can host you dyno plots for you. Hit me up in IM or EM.
New User
those are great numbers
i put down 172 whp and 165 tq at 8.5 psi
my setup is a little different, d16y7 non-vtec
cant wait to get my vtec head on
holy moly....those are some impressive times there buddy. 13.6's are really close to what I wanna run in mah car....hmmm....right now my setup is a D16Z6 stock with I/E in a DX EF and i onlee hit a 14.9...mang...what more if i slapped a freagin' greddy turbo...man...youve given me new hope. How much was your turbo kit? and how hard was it to install???...i wanna hit 13's on 5 psi...
Re: Ran my car- awesome results! (josEF)
The kit is $1500, intercooler is $700. BOV is $180. Takes a few hours to install if your are mechanically inclined and have tools.
I sent "sushibug" my dyno and timeslip and he said he'll post them for me, so they should be up soon.
nice times man!!! good job!! hey, did you go to Pacific raceways? was this last night at the high school drags? ill be there wednesday night for the night drags man, ill see you there!!
Re: Ran my car- awesome results! (Mista Bone)
Mista, I like having my power at all times and not refilling bottles, but to each his own.
By the way, what would your car run on street tires instead of slicks?
Re: Ran my car- awesome results! (pagong)
Yeah, I was there. My car is a red hatch with CF hood, GSR Blades on the back, stocks on the front. What were you in?
D Tranny Guru
I would guess about 13.9-14.1 area because I'm so used to launching at 6500-7000 rpms. I'd just blow the street tires off!
Besides, slicks are more consistant.
Yeah, I launch at 3800-4000 rpm. I basically dump the clutch and let it spin at 1/2 throttle until it hooks, then gun it, and it spins in 2nd gear for a sec and then hooks again. Its all good from there.
I'm torn between running some of the new BFG drag radials, or just getting some slicks. Any thoughts?
D Tranny Guru
slicks, they will hook better.
Unless you don't feel like changing tires at the track.
BTW Jegs has the cheapest prices on the Gforce drag radials.
They are sticky! I have a set in 225/50/15 for my low powered 86 TA.
I think I'm gonna do the BFG drag radials, seems like people are really liking them. I'll get slicks later.
I have 2 rim choices, my stock 14" x 5"? or 6"?
or
my gsr stocks, 15" x 6"?(i think).
Do you think the 205/50R14 would fit the stock steelies? The stock tires are 185/60-14's. Or would the 205/50R15 be a better choice?
or
Re: Ran my car- awesome results! (tonydatyga)
I have the Z10 bars, but I think I need to adjust them more because I still get some wheelhop in 1st.
