Turbo install question
Old May 5, 2002 | 12:17 AM
2camsaam's Avatar
Default Turbo install question
I have a 1995 Civic Ex coupe
I am putting a new motor in my car tomorrow and a turbo.
Should I put the new motor in first, then install the turbo?
OR...
Should I put the turbo on the motor first, then install motor with the turbo already on it?
Old May 5, 2002 | 01:24 AM
turbocoupe's Avatar
Default Re: Turbo install question (Spool)
What turbo? Do you have an intercooler?
Mods move this to the FI forum please.
Old May 5, 2002 | 07:56 AM
falcongsr's Avatar
What is this crap?
i would install motor first. get everything running / broken in. and then install turbo.
Old May 5, 2002 | 11:59 AM
sushibug's Avatar
Default Re: Turbo install question (falconGSR)
dont install the turbo for 1500 miles. that way if something is wrong with your car, you will know if it is turbo install related...
Old May 6, 2002 | 06:22 AM
2camsaam's Avatar
Default Re: Turbo install question (sushibug)
The motor has already been broken in. Do I still need to install the motor first, then the turbo?
I will be starting this afternoon.
Old May 6, 2002 | 07:19 AM
CovertFI's Avatar
if you have ac and the shroud in. install the turbo after the motor. if you have all that **** removed you can install it before. also i dont know about yall but it is a bitch to mount the turbo to the manifold. so i would try to install the turbo to the manifold before you put the manifold on the block. hope that helps
j-bird20
Dec 17, 2006 06:41 PM
Eckz2k
Jul 17, 2003 04:41 PM
B_1_8_hatch
Jul 11, 2003 06:51 PM
