difference using headgasket to lower compression instead of lower compression pistons ?
Old Dec 19, 2002 | 05:44 PM
C-Murdock's Avatar
Default difference using headgasket to lower compression instead of lower compression pistons ?
Just wondering, since I have 10:1 pistons and use the Inline Pro Headgasket which lowers my compression, will it make different power if I just had say 9:1 Pistons ?
Old Dec 19, 2002 | 05:57 PM
I_know's Avatar
Default Re: difference using headgasket to lower compression instead of lower compression pistons ? (C-Redru
I just posted the same question https://honda-tech.com/zerothread?id=364355
so I wanna know too
ninesecrx's Avatar
It changes timing...
Old Dec 19, 2002 | 06:02 PM
Sonny's Avatar
The thicker than stock headgasket will alter cam timing in relation to the crank. You will need adjustable cam gears to compensate for this. The measurement is something like 1 deg per .012" added/removed.
Sonny
Old Dec 19, 2002 | 06:07 PM
AlphaKennyWun's Avatar
wuz up yo! Ive had a few too manyh so what kinda pistons you got yo? Im on myh second set of JE pistons yo. If you got JE your da **** yo!
Old Dec 19, 2002 | 06:10 PM
C-Murdock's Avatar
yo I got Arias 10:1 yo....
Old Dec 19, 2002 | 06:22 PM
Elite Hatch's Avatar
Sonny
Uhh your getting too technical...and its not 100% true.
Old Dec 19, 2002 | 06:29 PM
I dunno yo...as long as you got stronger pistons and rings than stock and less than 10:1 comp with yo inline headgasket and tuning you should be straight. Ive got 8.8:1 JE comp yo.
Old Dec 19, 2002 | 06:33 PM
C-Murdock's Avatar
Just wondering whats up with the weird talk...Is this your form of critisizing me kus of my posts about Golden Eagle ?
Back to the topic, some people have told me 9:1 Compression pistons and stock headgasket will make more power than 10:1 pistons and an inline pro head gasket
Old Dec 19, 2002 | 06:45 PM
nah yo just had about 15 cranberry vodkas (grey goose) right about now thats all hehe .... but i think your straight just get your block fixed and tune it. you probably got about 9:1 i would guess with dat headgasket right? do a compression test...Ive got 155 psi compression in cylinders so 8.8:1 approx for me....
Old Dec 19, 2002 | 06:48 PM
Sonny's Avatar
Really? Educate me. I'd like to know what isn't "100% true".
Sonny
Old Dec 19, 2002 | 06:54 PM
C-Murdock's Avatar
nice...Grey Goose is very good vodka !!!
Getting drunk and getting on Honda-tech
VVENOM800TT
Feb 17, 2011 02:48 PM
My_EP3
Apr 6, 2004 06:27 PM
I_know
Dec 21, 2002 07:07 AM
gsrteg
Oct 24, 2002 11:56 PM
