No Hondata Blue Box or Chip????
Ok, I sent in my Hondata stage 2B to upgrade to the S200 system a while ago and I heard that the car is still drivable but it has something like a 3500 rpm revlimiter and a 1psi boost cut... Well my question is that I sent Hondata my chip as well because they said they were going to upgrade it to the V3. Can I drive the car without the chip at all, or just without the blue control box? Thanks...
Sean C.
Sean C.
Smarter than you
Re: No Hondata Blue Box or Chip???? (20lb.teg)
thats a good question. I think if the chip is out it runs just like a stock ECU.
I wonder if having peak and hold injectors and resistor box would do anything wierd on stock ecu. and if ur running bigger then 440 i wonder if it would even start.
Re: No Hondata Blue Box or Chip???? (b18onboost)
Well, one the G-Sensor, the others... You'll see soon.
Well i tried it and it would start then die. It wouldn't even do anything. I put another OBD-1 ECU in (no hondata, or anything) and it would barely drive because I have 550cc injectors That thing was crazy!!!! Well thanks for the help.
Later,
Sean C.
Later,
Sean C.
