70mm Throttle Body's
Old Dec 17, 2002 | 05:48 PM
crxhybrid1320's Avatar
Default 70mm Throttle Body's
I'm running the JG Intake Manifold with GSR
engine w/Boost.
With 70mm T.B. should I use.
Ericks
BBK
What Others and costs?
Is the throttle plate on these 70mm or does it taper?
[Modified by crxhybrid1320, 2:49 AM 12/18/2002]
[Modified by crxhybrid1320, 11:34 PM 12/18/2002]
Old Dec 17, 2002 | 08:23 PM
BrokenVtec's Avatar
Default Re: 70mm Throttle Body's (crxhybrid1320)
spoon makes a nice one....only downfall is the $$
Old Dec 17, 2002 | 08:25 PM
Dancing is Forbidden's Avatar
Default Re: 70mm Throttle Body's (BrokenVtec)
Arent they all just bored out OEm throttle bodies?
Old Dec 17, 2002 | 08:43 PM
Boostfed's Avatar
New User
I have a Holley 68mm TB for sale $175 plus shipping, email me dragnsi@mindspring.com or call my cell (757)343-1123 Terry
Old Dec 17, 2002 | 09:01 PM
BrokenVtec's Avatar
Default Re: 70mm Throttle Body's (EF9_SiR)
yeah...Spoon Bores out the factory one to 70....i just have a thing for OEM quality...
Old Dec 17, 2002 | 09:06 PM
BodyKits NW's Avatar
Ericks Racing. Awesome Quality.
tony1's Avatar
Only problem with spoons is that the butterfly isn't 70mm, it's just a taper bore. Starts at 70mm and tapers down to 62mm i believe.
Old Dec 18, 2002 | 05:52 AM
GraphiteAccord's Avatar
Default Re: 70mm Throttle Body's (Boostfed)
Does the holly have any problems sticking at all?
Old Dec 18, 2002 | 05:11 PM
TREVER's Avatar
Default Re: 70mm Throttle Body's (GraphiteAccord)
STR billet 70mm
Old Dec 18, 2002 | 07:28 PM
BrokenVtec's Avatar
Default Re: 70mm Throttle Body's (tony1)
Tony Just Owned me.....lol i did some measurments after really looking at the throtle body and now am sending it back... on me
Old Dec 18, 2002 | 07:51 PM
tony1's Avatar
Hate to be the bearer of bad news, but I guess it's okay if you can get your money back. Just ask me before you buy anything else
Old Dec 19, 2002 | 03:38 PM
Tony which would you choose the Erics, BBK, or STR
I know that the BBK comes with a block-off to eliminate the coolant passage
to cool the air temperatures.
Do thet all have the same features.
Thanks
Old Dec 19, 2002 | 04:12 PM
TREVER's Avatar
none of them has coolant lines
Old Dec 19, 2002 | 08:00 PM
tony1's Avatar
From what i've seen, the erick's is the best quality. The bbk is junk and I haven't seen the str in person. Go with erick's, you can't go wrong.
Old Dec 19, 2002 | 09:38 PM
ninesecrx's Avatar
STR is the same as Ericks...if it were me, id take the screws out of either tb that hold the butterfly on because they are not riveted on like a stock and can back out. Use some loc-tite on them so it cant happen and you will be fine.
Old Dec 20, 2002 | 06:38 PM
Default Re: 70mm Throttle Body's (ninesecrx)
Well the BBK I know yoy can use the factory collant hoses to run through the T.B. This is for cold start to heat the intake air temperatures. The BBK I know has a block off plate to elimate this.
Why is the BBK junk. Just wondering I know someone with it and doesnt have any problems?
Jason
Old Dec 20, 2002 | 08:04 PM
tony1's Avatar
not necessarily that it has alot of problems, it's just not built as good a quality as others. Put a bbk next to erick's and you'll see the difference.
ImportAutoPerformance.com
Performance
355
Mar 25, 2013 11:48 AM
Performance
298
Mar 21, 2011 05:42 PM
Performance
141
Nov 13, 2008 08:45 AM
StockBlkEK
Aug 5, 2002 04:09 PM
