what are you d-series guys bored at?
just wondering what you guys are bored at, and are you having any cooling issues? yes this refers to you stock sleeved, and resleeved guys...thanks
Re: what are you d-series guys bored at? (98civicEX)
I'm sleeved but running the stock bore size. I figure itll be stronger with more meat on the cylinders thats why i didnt go oversize.
I was bored with my d motor so i went b
To help answer somehow. After I did my Darton pro sleeves my car runs a bit cooler. Stock cooling system is intact.
stock sleeves .020" so I could fit my JE pistons in.
not boosted yet so I can't give you much info on cooling. W/o boost and a blockguard, I'm running really cool though.
after i am done with my block, it will be 77mm. i have heard that the biggest GE recommends for boosted blocks is 78mm, and after that, the walls become too thin between cylinders. 77mm with stock stroke (90mm) will put displacement somewhere around 1.7 i believe. i did the math a long time ago. i just bought my spare block and tore it down yesterday, but im trying to decide GE or Darton for my sleeves.
david
david
1 Post
Re: what are you d-series guys bored at? (00TurboEX)
on street applications we recommend to limit at 77mm.
we are desinging turbo and all motor applications for the D series on a 77m bore at this time. should be available in february.
wIl
wIl
