What in the hell is goin on here! manifold bolt backin out...
got a rev hard mani on my h23 prelude. the drivers side lower bolt keeps backing out.. its just that one. it leaks and makes a nasty sound at idle.. once it warms up its fine.. can i use locktight on that? no boost leak though..
Guest
Posts: n/a
Re: What in the hell is goin on here! manifold bolt backin out... (BoostedH23a1)
loctitie blue will hold the heat no prob. I used it on the turbo flange nuts and studs, downpipe studs and bolts, and everything works perfectly. Your fine with loctite. I would used "blue" cause its is supposed to be serviceable in the future. As in, you can remove those bolts with air tools. loctitie red isnt so friendly
Re: What in the hell is goin on here! manifold bolt backin out... (Night_Minx)
Loctite will not hold up to the heat in the manifold. You can put it on and it won't hurt anything, it just doesn't work properly. Use a lockwasher if you're having problems.
Re: What in the hell is goin on here! manifold bolt backin out... (tony1)
Thermal expansion and vibration makes them back out sometimes. I have seen it happen on a warped manifold flange as well.
Re: What in the hell is goin on here! manifold bolt backin out... (ninesecrx)
Re: What in the hell is goin on here! manifold bolt backin out... (Jared)
man i dont wanna take that off and shave it! pain in the ***.. damn rev hard... aha
