will it be safe? and fast?
Old Dec 19, 2002 | 03:41 PM
accorracer's Avatar
Default will it be safe? and fast?
ok i need opinions my set up consists of a t3t04 turbonetics with a ar of 50, all drag piping a 32 1/2'' x 10'' intercooler ,drag manifold and downpipe,delta gate with 6 psi spring and a stock block with stock injectors will i be ok the only thing i have to tune with is a vafc and a fmu w/ 12.1 disc
its all going on a 94 jdmh22accord, will i detonate after dyno tuning btw, i am running a p28 with a skunk2 chip,walboro 255 intank fuel pump and colder plugs
and yes i know i need a tial wastegate
Old Dec 19, 2002 | 07:08 PM
accorracer's Avatar
Default Re: will it be safe? and fast? (accorracer)
bump
Old Dec 19, 2002 | 07:10 PM
MayhemSi's Avatar
na ecu mods are terrible for boost. I wouldn't risk it with stock injectors, but its not my car. It might work, but not for long.
Old Dec 19, 2002 | 07:28 PM
cock head's Avatar
dump the ecu, and the fmu get a stock ecu and 450 injectors you already have the afc you will be better of with the hack.
Old Dec 19, 2002 | 08:30 PM
T-sohctec's Avatar
UHUHUHHHhaahhh :::shivvers::: I get the heebie jeebies everytime someone says they are sticking with stock injectors. You can get 450 DSMs for 60 bucks for christ sakes. If you can't spring for that then where did you get the Turbo in the first place?
I don't know why people do it but they do.
don't push that thing too hard mang
Old Dec 21, 2002 | 03:14 PM
accorracer's Avatar
Default Re: will it be safe? and fast? (T-sohctec)
why get dsm 450's when i have 345's now i'll just get some bigger ones later my car runs rich as hell w/o the turbo so i figure bump my fuel up with the vafc and it will be good once i get it on the dyno
Old Dec 21, 2002 | 03:27 PM
Blaze45's Avatar
Brrraaaap!
http://www.rceng.com play w/ the injector flow rates here. I saw some 450s for 50 bucks the other day. Spend the money. W/ the chip you have it advances timming and dumps fuel unevenly so thats why your car runs rich w.o the turbo. If you gonna turbo, pay 75 (max) or 1300 for a rebuild lattor....Put the stock ECU back in, and retard timming .7 degrees for every pund of boost.
Type-X
Feb 7, 2005 11:00 AM
Cezilla
Mar 28, 2004 08:21 AM
01ITR#700
Jan 29, 2003 08:12 AM
1bar
Jan 22, 2003 07:44 AM
accorracer
Dec 19, 2002 03:40 PM
