ok, dont flame. Oil pan fitting for oil return line.
1 Post
I dont want to weld the oil pan. what fitting do i use instead??? The return oil line should be -10 an or so right??? what about the oil feed?? -4 will work???
Re: ok, dont flame. Oil pan fitting for oil return line. (DIY_Racing)
that sounds about right.
be sure to clean the area, and use JB weld as well. if done right, it will hold just as good as a weld job.
worked on my integra for 5 months before it was stolen.
This is what you want. Just make a 7/8" hole where you want your return drain. Insert the fitting put on the washer and tighten the nut and you are in biz.
Re: ok, dont flame. Oil pan fitting for oil return line. (earl)
Re: ok, dont flame. Oil pan fitting for oil return line. (1.8T_EG)
Are those Earls (the brand) parts? Does it come with that seal (o-ring thing) on the fitting?
Oh yeah, anoyone know where to get some -3 SS hose and fitings online??? As I heard, Areoquip makes the stuff, but I can't find ithe stuff online.
Re: ok, dont flame. Oil pan fitting for oil return line. (InfamousRS)
As far as I know, you have to buy each part seperate unless someone puts them together as a kit. That one washer is called Dowty Seal and costs about $10 by itself. I think all the parts were around $25 or so. All is available thru Earl's (no relation)
http://www.summitracing.com has a whole lotta fittings... earls, aeroquip... they're surprisingly quick on delivery too.
Re: ok, dont flame. Oil pan fitting for oil return line. (SiRkid)
May I ask you why you dont want to weld? Welding a bulk fitting is more secure and fool-proof. Less chance of leakage and long term issues where as, with the fittings, it my come loose or not seal properly causing oil leaks.
Re: ok, dont flame. Oil pan fitting for oil return line. (a z n t a k)
It seals with o-rings on both sides and you would install the nut with loc-tite. Welding is just as good for an install but the welds can break or leak plus not everyone has access to a welder. This is a project that a noob could do himself. We will probably weld our fitting in and I will probably sell this set-up
I checked Summit for -3 lines...they dont have any listed...does anyone know where I may beable to find some?
my homies using the earls speed flex hose .. its relativley cheap !!! about 30$ for liek 4 feet with fititngs on them ... you can check out amstreetrod.com
Re: ok, dont flame. Oil pan fitting for oil return line. (project dc2)
Re: ok, dont flame. Oil pan fitting for oil return line. (Ruckus138)
RyanAutry
05-06-2003 12:37 PM
