what exactly does a missing link or check valve do?
Old Dec 21, 2002 | 08:36 AM
wickedxboi's Avatar
Default what exactly does a missing link or check valve do?
i did a search and nothing really came up. i was wondering if i will need either one. i have a 99 b18b with a drag 3 kit. i want to use a fmu set up for now until the smc comes out. what does it exactly do and is it nessecary? any info would help..thanks
Old Dec 21, 2002 | 09:41 AM
memphiss13's Avatar
Default Re: what exactly does a missing link or check valve do? (wickedxboi)
it tricks the MAF sensor basically. if that sees too much boost you will have a CEL
Old Dec 21, 2002 | 09:24 PM
wickedxboi's Avatar
Default Re: what exactly does a missing link or check valve do? (rookie2nr)
does anyone how much boost before i throw a cel?
Old Dec 21, 2002 | 10:16 PM
Tyler H's Avatar
Stock Honda ECU's expect to see a maximum manifold pressure of atmospheric. (0 psi on your boost guage) If it sees any boost at all, it should throw a CEL. The Drag kit probably came with check valves to prevent this.
Tyler
Old Dec 21, 2002 | 11:17 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: what exactly does a missing link or check valve do? (Tyler H)
yeah, basically once it reads positive vacuum (boost) and not negative vacuum, you will get a light (cel)
Old Dec 21, 2002 | 11:32 PM
wickedxboi's Avatar
Default Re: what exactly does a missing link or check valve do? (SIXTYdashONE)
does the cel affect performance? doesnt it go to loop mode or something?
Old Dec 21, 2002 | 11:38 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
yeah. your going to need this. i have a throttle body mount missing link. forty bucks shipped and it's all yours.
Old Dec 24, 2002 | 04:45 PM
wickedxboi's Avatar
Default Re: what exactly does a missing link or check valve do? (not so civic)
people are telling me 12:1 is over kill and to use a 10:1 disk and a intank.....will this work well on stock injectors?
Old Dec 24, 2002 | 04:49 PM
Elite Hatch's Avatar
I use 10:1, Walbro Intank, and 440cc injectors and run 1 bar. Works perfect
Old Dec 24, 2002 | 06:42 PM
flip1199's Avatar
what's the max amount of boost that can be obtained using the missing link.
elpiar
Mar 22, 2005 06:02 PM
TRE_
Nov 7, 2004 12:26 AM
iwouldHITit
Feb 9, 2004 07:35 PM
integraracer94
May 23, 2002 04:19 PM
