Fuel Help?
Old Dec 19, 2002 | 05:42 AM
Tony Starks's Avatar
Default Fuel Help?
I was reading another thread that concerned me due to my set up. Here are the specs, I currently run 8 psi...
D16y7/ garrett T3 w/ internal wastegate/ 12:1 FMU/ stock intank/ stock injectors/ B&M regulator/ intercooled/ cold ngk's/ blitz bov/ apexi TT/ usual gauges
I'm not detonating until 6,000 rpm, sometimes. Is my stock pump supporting my FMU o.k.? My AF gauge never leans out, but it's an autometer. Is 8 psi too much? Should my timing be adjusted? Any suggestions and recommendations are GREATLY appreciated. Thanks in advance.
Old Dec 19, 2002 | 06:28 AM
swrdply400mrelay's Avatar
Default Re: Fuel Help? (Huck)
You're not getting enough fuel. Autometer is junk; I know because I have one. Upgrade your pump or go with the AFC hack.
Old Dec 19, 2002 | 06:32 AM
Default Re: Fuel Help? (swrdply400mrelay)
would an inline do the trick?
Old Dec 19, 2002 | 06:34 AM
Yes. In the mean time, turn down the boost if you can.
Old Dec 19, 2002 | 06:38 AM
Thanks. Now I'll run a search to find an inline install.
ridnmyhonda
Jan 29, 2003 09:35 PM
freeplay
Dec 8, 2002 11:03 AM
b18cx
Dec 1, 2002 05:03 PM
zcivic91
Jul 30, 2002 08:58 AM
fast[R]
Apr 27, 2002 06:09 AM
