Dumb ass manifold question
Old Dec 20, 2002 | 03:28 PM
TheHater
Guest
Posts: n/a
Default Dumb *** manifold question
Straight newbie question. Why do some manifolds curve up then down? Better air flow or something? IDUNNO
Old Dec 20, 2002 | 03:57 PM
mos's Avatar
mos
Default Re: Dumb *** manifold question (BOOSTINSI)
It's to keep the length of each primary runner the same length. There is only so low you can go with turbo location. This is because the turbo depends on gravity to drain the oil out. Therefore the turbo must remain higher than the oil level inside the oil pan.
Old Dec 20, 2002 | 04:02 PM
tominos's Avatar
Default Re: Dumb *** manifold question (mos)
i thought it was so that all the exhaust gases reach the turbo at the same time, so that it flows better or something, just a guess. i didn't know it had anything to do with oil drain on the turbo.
Old Dec 20, 2002 | 10:14 PM
mos's Avatar
mos
Default Re: Dumb *** manifold question (tominos)
Well you are right. My point was that you could make an equal length manifold that didnt rise above the exhuast ports at all, but then you would have problems draining the oil. The designs that bend up and above the exhaust ports do so, in part because the drain on the turbo needs to be located above the oil level.
Old Dec 20, 2002 | 10:17 PM
Full-Race Javier's Avatar
the less bends..... the better
Project99EK
Dec 29, 2004 03:32 PM
nonvtecD
Nov 9, 2004 04:36 PM
B18c1CivicTurboed
Jun 3, 2003 08:33 AM
Damon B.
Dec 14, 2002 10:27 AM
