zex nitrous bottle warmer
Old Dec 17, 2002 | 12:39 PM
tek_civic's Avatar
Default zex nitrous bottle warmer
ok so i know that the nitrous express warmer works via a pressure sensor so that it remains at a constant 900psi. i just bought a zex bottle warmer that only works via temperature so if i flip it on when the tank is full it would raise the pressure to a point where it it could cause the safety valve to burst, or if i turn it on when i only have like 3lbs on N20 left it might not raise it to the desired 900psi. are my theories correct? any light on the subject would help a lot. thank you!
Old Dec 17, 2002 | 01:19 PM
Night_Minx
Guest
Posts: n/a
Default Re: zex nitrous bottle warmer (tek_civic)
actually, you even need a bottle warmer. Just tun the oven to 450, and stick the bottle in there for 1 minute.
On another note, i had the ZEX bottle warmer, works really well. Your pressure will stay consistent. make sure you connect it to a proper source, I forgot where I did mine, but you need at least a 25 amp source.
Old Dec 17, 2002 | 08:31 PM
tek_civic's Avatar
Default Re: zex nitrous bottle warmer (Night_Minx)
ok thanks, i plan on wiring it into my amp power. i am running like 8 gague wire and my sub/amp combo is soo weak that it doesn't come even remotely close to using what can be supplied.
ZexyAccord
Nov 13, 2004 08:47 PM
MooreBoost
Sep 8, 2003 04:53 AM
See Are X
Nov 6, 2002 07:54 PM
