Resleeving
Old Dec 20, 2002 | 06:07 PM
Islander's Avatar
New User
Default Resleeving
I would like to know if it's necessary to resleeve the Integra LS motor to run forged pistons. Also, is it true that it's better to use Honda rings with forged pistons once you're running factory bore diameter?
Old Dec 20, 2002 | 06:31 PM
ekb18c's Avatar
Default Re: Resleeving (Islander)
No, you don't have to resleeve your LS motor to run forged pistons. I use the rings the piston manufactor supplies.
Old Dec 21, 2002 | 04:59 AM
20lb.teg's Avatar
Default Re: Resleeving (ekb18c)
No, you don't have to resleeve the ls motor to run frorged pistons. About the rings, I have JE Pistons and the XC rings come with it. I would HIGHLY recomend using their rings but they are file-to-fit, so if you don't know exactlly how to do that I would highlly recomend letting a machine shop do the ring filing and gapping (or an experienced friend...) but yah so I would NOT use honda rings... I would use XC rings. Some say gapless are nice... I don't know it's up to you... HOpet his helps.
Later,
Sean C.
Old Dec 21, 2002 | 05:44 PM
fbiguy007's Avatar
how about an f22a6 or 1 do they need resleeving i know the h22a does?
Old Dec 21, 2002 | 05:55 PM
ski_rebel_3's Avatar
I am a firm beliver in the fact that if you are going to open up the motor to change the pistons and rods then you may as well just go ahead and sleeve it at the same time.
Old Dec 22, 2002 | 08:35 AM
Islander's Avatar
New User
Default Re: Resleeving (20lb.teg)
Would you recommend low silicon or high silicon pistons using the stock sleeves? With pistons and rods how much boost you think the stock sleeves can handle? Would I need to use a block gaurd? Also, when you say they are file to fit which part of the rings are actually filled? Pics would be nice.
Thanks
MurtazaDSM
Feb 14, 2015 07:54 AM
912
Dec 25, 2005 08:29 PM
N20civicB18
Jul 28, 2004 07:39 AM
CRXGSR
Nov 4, 2002 05:47 PM
