g sensor module - hondata
Old Dec 20, 2002 | 04:15 PM
bonesix's Avatar
Default g sensor module - hondata
anyone have this? seems very interesting
Old Dec 20, 2002 | 10:33 PM
Slick GS-R's Avatar
Default Re: g sensor module - hondata (bonesix)
*bump*
Old Dec 21, 2002 | 01:35 AM
bonesix's Avatar
Default Re: g sensor module - hondata (Slick_GS-R)
come on now! i know someone has!
Old Dec 21, 2002 | 10:34 AM
Spunkster's Avatar
I have one and will post my results alongside real dyno runs
Let me know what info you wanna see.
Old Dec 21, 2002 | 10:37 AM
falcongsr's Avatar
What is this crap?
it just was announced so give it a little while.
Old Dec 21, 2002 | 11:39 AM
GraphiteAccord's Avatar
Default Re: g sensor module - hondata (Spunkster)
hey matt, how's hondata? gonna get a fellow tucsonan a job there?
Old Dec 21, 2002 | 12:13 PM
avividmemory's Avatar
Default Re: g sensor module - hondata (GraphiteAccord)
i read up on it on there site, but i dont exactly understand what it does...someone help me in "kevin terms"
Kevin
Old Dec 21, 2002 | 04:54 PM
Hondata's Avatar
Default Re: g sensor module - hondata (SpoolinLS)
The G sensor does several things.
It tells you your cornering Gs.
It tells you how fast you are accelerating and braking in Gs.
If you enter your car's weight and gearbox ratios, it will accurately give you a power and torque curve.
You can use this as a tuning tool to measure changes in power due to changes in fuel and ignition.
This is real world tuning. You are measuring you power on the road, where your acceleration rate and airflow can be quite different to the dyno.
Download the hondalogger dyno demo from here : http://www.hondata.com/downloads.html
[Modified by Hondata, 6:01 PM 12/21/2002]
Old Dec 22, 2002 | 09:14 PM
Default Re: g sensor module - hondata (Hondata)
sounds like it might be helpful in self tuning
Old Dec 22, 2002 | 10:07 PM
racerxadam's Avatar
any more info on the sensor itself? I want to integrate a g sensor into my engine management system and I'm not running hondata.
Old Dec 22, 2002 | 11:07 PM
Drew Peacock's Avatar
Default Re: g sensor module - hondata (racerxadam)
If anything it sounds like Hondata are copying the mighty Apexi RSm how accurate is that when calculating G forcessssssssss?????????
Old Dec 22, 2002 | 11:34 PM
KOTSEMOTO's Avatar
Default Re: g sensor module - hondata (turbozxi)
they are not copying APEX'i. They do have a similar product. The Rsm uses an optonal G sensor. Hondata uses it datalogger.
Can you datalog data From the RSM?
Read their article about the G sensor. Hondata has a very good technical support and they did mention something about the accuracy of the Gsensor.
These is a very useful tool for part throttle tuning since dynojets are used for power runs only.
Old Aug 17, 2003 | 02:38 PM
int3gra's Avatar
Default Re: g sensor module - hondata (KOTSEMOTO)
how many more are using this now?
Old Aug 17, 2003 | 05:03 PM
SOUNDEFFECTS's Avatar
Default Re: g sensor module - hondata (int3gra)
I'd like to know who has run the sensor successfully so far
Dunc
Feb 7, 2007 10:23 AM
cptengineer
Nov 1, 2005 06:36 PM
SuperImport
Apr 12, 2005 05:55 PM
the-anti-crack
Sep 25, 2003 02:08 AM
Hondata
Dec 10, 2002 03:05 PM
