Car running like crap
Old Dec 19, 2002 | 12:49 PM
hybrid901's Avatar
Default Car running like crap
One of my buddys with a 95 turbo gsr car is running like crap. The bolt on his crank pulley backed out and the belts came off. I think he might have jumped a tooth on teh cam gear. I haven't been able to look at it yet. He told me the car will rev fien with the car in neutral but when your driving it with a load on it it stumbles and has no prower and if you give it full throttle it will just bog and die. Any suggestions?
Old Dec 19, 2002 | 12:55 PM
littlebluecrx's Avatar
Default Re: Car running like crap (hybrid901)
first off I would make sure the crank key way did not get messed up, then I would line the crank, up to tdc, and check that the timming is line up, then I would go from there. Jason
Old Dec 19, 2002 | 12:58 PM
hybrid901's Avatar
Default Re: Car running like crap (littlebluecrx)
Would the timing being off by a tooth cause this problem.
Old Dec 19, 2002 | 01:33 PM
With the timming off the car may have even bent valves that can cause problems. Jason
Old Dec 19, 2002 | 01:38 PM
b18bturbo's Avatar
definietly looks like bent valves what is his vacuum look like on the boost guage really low or what now.
Old Dec 19, 2002 | 02:02 PM
hybrid901's Avatar
Default Re: Car running like crap (b18bturbo)
Can the valves hit the pistons just being off by one tooth.
Old Dec 19, 2002 | 02:12 PM
vw-honda-hatches's Avatar
depends on decked head, piston size and compression.... jun stroked b16 with jun head gasket. It went off a tooth, didnt bend a thing.
Old Dec 19, 2002 | 03:45 PM
hybrid901's Avatar
Default Re: Car running like crap (vw-honda-hatches)
b18c1 9:6:1 comp, stock head gasket, block and head not decked that I know of.
[Modified by hybrid901, 12:45 AM 12/20/2002]
carlos8
Jan 19, 2014 11:11 AM
94eg!
22
May 8, 2006 08:07 AM
R_type
Jun 6, 2005 06:05 PM
Chubz
Apr 20, 2005 09:10 PM
