what size injectors do i need ???
Old Dec 18, 2002 | 02:56 AM
Cyber ITR's Avatar
Default what size injectors do i need ???
currently running 550cc's @ 6psi ( i know its overkill )
the new setup will be built B18C1 with t3/60-1 , thinkin to boost the bitch around ~25psi max
thanks guys
Old Dec 18, 2002 | 03:05 AM
boostaholic's Avatar
Default Re: what size injectors do i need ??? (VTEC_SiR)
depends how much whp you plan to support. With that setup i'm guessing you're looking to hit 450-500whp, some 85lb inj. outta be enough. You can never go overkill on the fuel w/ boost
Old Dec 18, 2002 | 03:59 AM
C-Murdock's Avatar
Default Re: what size injectors do i need ??? (boostaholic)
72lb/hr injectors will be fine...
Old Dec 18, 2002 | 04:02 AM
racerxadam's Avatar
There is a calculator to help give an idea toward the bottom of this page. http://www.rceng.com/technical.htm At 90% duty cycle, .6 BSFC, fuel rail pressure of 65 psi, and a max desired output of 500 hp it seems that you would need around 70 lb/hr injectors
[Modified by racerxadam, 8:04 AM 12/18/2002]
Old Dec 18, 2002 | 05:14 AM
ArizonaTurbo's Avatar
MSD 72lb/hr injectors
http://www.store.yahoo.com/sr20perfo...msd72lbin.html
central_driver
10
Feb 18, 2009 09:33 PM
B6teen
Jan 8, 2008 07:46 PM
l3 o r e d
Aug 26, 2006 04:46 AM
mrkal
Jan 22, 2006 05:23 PM
Ek00fbp
Jan 31, 2004 07:33 AM
