Turbo on ZC
Old Mar 7, 2003 | 05:37 PM
BoostedCR-X's Avatar
Default Turbo on ZC
hi,
I recently bought a 16G turbo and want to put it on my ZC motor.
Im trying to find various parts and would like any info that oyu all could give me.
I need to find an FMU, and a plate adapter in order to fit the turbo to a HF manifold.
Also, is there anything i should look out for?
righ tnow im only planning a maybe 4-5 psi, im not sure how high i could go with a stock block, fmu, boost controller and fpr
i plan on rebuilding hte motor, have some pistons dropped in ( possibly 89 teg flat top pistons) to lower compression, and a safc, bigger injectors, etc.
thanks,
Scott
Old Mar 7, 2003 | 06:41 PM
speedworks's Avatar
Default Re: Turbo on ZC (BoostedCR-X)
about 13 pounds the rods will bend and the ringlands will break.
Old Mar 7, 2003 | 06:44 PM
liam821's Avatar
25 Year Member
Default Re: Turbo on ZC (speedworks)
i dont agree. The ZC shortblock is almost identical to a z6 and y8. There is many people, like myself, on this board that have run 15psi or more on stock d16 blocks without them breaking. Tuning is key.
liam
Old Mar 7, 2003 | 07:22 PM
Sonny's Avatar
The 88-89 Integra pistons are not flat. They are domed and will yield 9.5:1 in a ZC using the stock headgasket. The 86-87 Integra pistons are flat and will yield 9.3:1 in a ZC with the stock headgasket.
Sonny
Old Mar 7, 2003 | 07:47 PM
boosted_zc's Avatar
Default Re: Turbo on ZC (Sonny)
If your planning on rebuilding, get Endyn's roller wave pistons. There a little pricey but sweet as hell. as for the adapter plate, just take your turbo and manifold to a machine shop, they'll make u one for like $40
Old Mar 8, 2003 | 01:42 PM
Default Re: Turbo on ZC (boosted_zc)
cool, thanks for the informations so far.
i have a couple more questions.
I have a blwon hf motor, so i have a manifold to use. is ther anything extra i need to do besides having an adapter plate for the turbo? and will the manifold need to be ported or anything before it bolts to a ZC? Also, will an HF oil pan fit on a zc? if so, where do i need to run the oil return line? i have a friend who can tap one for me, i just need to know where.
thanks again,
Scott
elvis3000
May 22, 2010 09:47 AM
speedd2286
Sep 7, 2005 08:23 PM
SLOAZZ95
Nov 7, 2003 09:33 AM
ridestrt
Oct 6, 2003 12:31 PM
SOHC_DK.
Nov 21, 2002 05:24 PM
