Help! Wierd problem
Old Mar 7, 2003 | 03:25 PM
MayhemSi's Avatar
Default Help! Wierd problem
So I was driving along today in my civic, and all of a sudden the speedometer stopped working. It twitched around a bit and then settled on 0. Now, the car idles at about 1300 rpms and it runs rich all the time and the air/fuel ratio gauge doesn't bounce like in open loop any more at all. Anyone had this problem or have a solution, please respond. I'm going crazy with this car. Thanks!
Old Mar 7, 2003 | 03:48 PM
MikeMAN's Avatar
Default Re: Help! Wierd problem (MayhemSi)
check were ur VSS plugs in
mike
Old Mar 7, 2003 | 03:55 PM
MayhemSi's Avatar
Default Re: Help! Wierd problem (MikeMAN)
<-- noob.. whats the VSS and where is it?
Old Mar 7, 2003 | 03:56 PM
turbod16y8's Avatar
do a search under speedometer and you'll get alot of info. it happened to me too. more info here
https://honda-tech.com/zerothread?id=379965
Old Mar 7, 2003 | 04:01 PM
MayhemSi's Avatar
Default Re: Help! Wierd problem (turbod16y8)
Right.. I just need to know where the VSS is located at. I will check the fuses, too and see if anything is grounded out. Thanks for the info!!
Old Mar 7, 2003 | 04:07 PM
B18C4-T's Avatar
If you look at your throttle body, then look straight down you will see a plug with three wires in it on the transmission, that is your Vehicle Speed Sensor (VSS) plug.
Old Mar 7, 2003 | 04:09 PM
MayhemSi's Avatar
Default Re: Help! Wierd problem (B18C4-T)
Thank you so much.. I'm off to check it out.. I'll report back
beat
Jun 7, 2010 01:33 PM
CRiSP
Jul 4, 2005 10:23 AM
socakracer974
Jan 26, 2005 01:11 PM
KEVlN
May 5, 2004 05:00 PM
Andy M
Apr 29, 2003 12:24 PM
