question about dsm injectors in a 4th gen
ive done a search, i know how to hook it up and everything, but i have two questions which i haven't found answers for.
1) will the honda injector plugs plug into the dsm injectors, or will i have to modify the plugs?
2) will the dsm injectors fit into the d16 intake manifold or will i need to modify the o-rings or anything?
thanks alot
spanky
thanks alot
spanky
Re: question about dsm injectors in a 4th gen (spankaveli)
so am i correct in understanding that because the 4th gen civic already has a resistor box because (from what i read) the older hondas had peak-hold injectors so they needed the resistor in the car stock? that means i should just be able to plug in the injectors, no splicing or anything?
thanks again.
thanks again.
1 Post
step one: Unplug stock injectors
step two: plug in dsm injectors
step three: bolt back in. if a good seal isnt created around each injector, take the plastic spacer out from behind each I.M. oring, and replace with another I.M. oring...ie, double up on orings...
step four: done
step four: done
