Why does my car stutter when hitting VTEC?
Old Mar 8, 2003 | 10:15 AM
MikeMAN's Avatar
Default Why does my car stutter when hitting VTEC?
I will be in first and punch it, its not too bad of a stutter, but if I am in second and I give it some gas, it hits vtec and bogs a decent amount.
Anyone with any ideas? Would the cause be too lean or too rich?
Thanks,
mike
Old Mar 8, 2003 | 10:20 AM
Zero_son's Avatar
Default Re: Why does my car stutter when hitting VTEC? (MikeMAN)
Running rich?
Old Mar 8, 2003 | 10:22 AM
MikeMAN's Avatar
Default Re: Why does my car stutter when hitting VTEC? (Zero_son)
i think i may be fine, i leaned it out a tad and it helped. I think the problem is the shop that did my engine swap used a GSR ECU..vtec at 4400.
I was wondering if anyone knows if a turbo would make this more pronounced? Because with my N/A setup it wasn't too bad of a stutter.
Thanks,
mike
Old Mar 8, 2003 | 10:25 AM
b18CT's Avatar
if your car bog when you hit vtec ,its bcuz your vtec is set to low you just need to upper your vtec
Old Mar 8, 2003 | 01:26 PM
BoostedGSRBubble's Avatar
Default Re: Why does my car stutter when hitting VTEC? (REVTurbo)
Yea, upper your vtec and then go get your hair did.
Old Mar 8, 2003 | 01:31 PM
MikeMAN's Avatar
Default Re: Why does my car stutter when hitting VTEC? (BoostedGSRBubble)
will do i figured it was the turbo making it more pronounced!
mike
Old Mar 8, 2003 | 02:01 PM
b18cx's Avatar
Just a thought, Have you checked your oil. Seems to be a plague of non working Vtec cars that forgot all about oil pressure. And then cant imagine why the motor smokes a few thouisand miles later???
Old Mar 8, 2003 | 02:23 PM
MikeMAN's Avatar
Default Re: Why does my car stutter when hitting VTEC? (b18cx)
nope, never checked my oil...cars use oil? im familiar with that problem, but thats not it. VTEC doesn't engage AT ALL if oil pressure is an issue.
mike
idea_jdm
10
Feb 5, 2006 05:09 PM
AXZ NYC
Feb 13, 2005 09:07 AM
hoya_10fintec
Feb 13, 2005 08:36 AM
lmiguelvv
Oct 19, 2004 06:55 PM
CompressionFed
Mar 23, 2004 04:54 AM
