AFC problem, help please :o)
Old Mar 7, 2003 | 04:10 PM
avividmemory's Avatar
Default AFC problem, help please :o)
So, i installed the SAFC V2 today...the car is completely apart but the battery and everything is still hooked up...and when i turned the ignition on, nothing no afc lighting up...however my stereo and everything else worked, so i established it wasnt a fuse or anything
Also, I check the connections twice over...they all look good and I made sure they are correct...so is this normal does it only come on when the car is on as apposed to just how i had it...keep in mind theres no motor in it really...
help me out guys...im stuck
Old Mar 7, 2003 | 04:12 PM
Default Re: AFC problem, help please :o) (SpoolinLS)
reply cuz i forgot to hit the email me a reply button...hehe thanks guys
Old Mar 7, 2003 | 07:35 PM
inspyral's Avatar
It should come on with the key in the II(ON) position.
Old Mar 7, 2003 | 08:21 PM
Default Re: AFC problem, help please :o) (inspyral)
hrm...im so confused on what could be wrong....
heres how its connected
Red-Power
Gray-Throttle
White-pressure out (towards car)
Yellow-Pressure in (close to ecu)
Black-Ground
Brown-Ground closer to ecu than black
Green-RPM
I'm pretty sure thats how i set it up...i may have confused the green and gray
Old Mar 7, 2003 | 08:28 PM
could it have anything to do with the way i spliced the wires, or the order in which i connected the grounds...im really at a loss, i guess tomorrow is back to the drawing board...
Old Mar 7, 2003 | 10:22 PM
inspyral's Avatar
As long as you got the power and ground hooked up right, it should at least turn on. How did you ssplice your wires? I know people recommend soldering, but I haven't had any problems using the splices that A'PEXi gives you.
allmotor-B
Engine Management and Tuning
12
Aug 29, 2011 04:21 PM
boostin GSR
Honda Civic (2001 - 2005)
Aug 15, 2006 09:18 PM
wadespade
Jul 27, 2004 05:27 AM
eL
May 26, 2003 12:23 PM
Duck Sauce
Aug 14, 2002 09:42 PM
