newb oil return line question
Old Mar 9, 2003 | 09:28 PM
metal-x's Avatar
Default newb oil return line question
is using a rubber hose for the oil return line a bad idea?
Old Mar 9, 2003 | 09:47 PM
Tinker219's Avatar
Default Re: newb oil return line question (metal-x)
not if its rated for high temp...being over 500degrees...
otherwise, yes very bad idea. My buddy lost all by 1 qt of oil through his line before he realized it. It expanded, then blew because of the heat....
Old Mar 9, 2003 | 09:56 PM
Flamenco-T's Avatar
Default Re: newb oil return line question (Tinker219)
true also, the lines will be more likey to be located next to the DP which gets very very hot.
Old Mar 10, 2003 | 04:36 AM
metal-x's Avatar
Default Re: newb oil return line question (Flamenco-T)
thanks for the info, I have the maxrev kit and it comes with a rubber hose I duno whats its rated for max temperature
hondatuner020
Apr 26, 2011 05:26 PM
stackz
Feb 28, 2008 01:49 PM
C1V1CS1
Oct 16, 2002 12:23 PM
Snafu-Si
Jul 2, 2002 07:58 AM
