What oil pan fitting?
Old Mar 9, 2003 | 12:18 PM
420aNT's Avatar
Default What oil pan fitting?
I used the 10an line for my oil return but I have no clue on what to use on my oil pan itself? Is there a piece that I can buy and weld onto the pan then connect the line to the pan? If so what is it and were can I get it? Pics?
Old Mar 9, 2003 | 04:37 PM
420aNT's Avatar
Default Re: What oil pan fitting? (18gTeg)
ttt
Old Mar 9, 2003 | 04:53 PM
Sleepin''s Avatar
I believe you will want a 10AN bulkhead connector and, once installed, cut the nipple portion off on the inside of the pan. People ensure these stay on in a lot of different ways, from Hondabond to JB WELD to actually welding or brazing it. Someone who has done this would be a better canidate for a response, I have only read about it as of yet.
Old Mar 9, 2003 | 05:29 PM
SuperT's Avatar
Go to AN fittings .com they sell the weld on steel bungs in -10 or -12...
Dave
Old Mar 9, 2003 | 05:32 PM
420aNT's Avatar
Default Re: What oil pan fitting? (SuperT)
Anyone else know were to get a 10an flange that I can weld to my oil pan?
Old Mar 9, 2003 | 05:55 PM
Ray's Avatar
Ray
New User
http://www.anplumbing.com
Part# 967110
-10an Steel Weld Fitting
I used a 1/2npt female
Old Mar 9, 2003 | 06:00 PM
bryan305's Avatar
Default Re: What oil pan fitting? (Ray)
why don't you get the -10an bulkhead connector then use the locknut on the inside of the pan?
http://store.summitracing.com/partdetail.asp?part=6289
Old Mar 9, 2003 | 10:19 PM
Flamenco-T's Avatar
Default Re: What oil pan fitting? (bryan305)
I have a -10AN to 3/8" adapter, all you do is get a 3/8" tap, then drill and tap your oil pan, screw this adapter in with a couple of crush seal washer and you're done...
if you're unsure, you can apply a l il jb weld around it
I have a -10AN weld on bung as well, if you can get access to a welder...
stan
Old Mar 9, 2003 | 10:26 PM
pagong's Avatar
I bought mine from Arturbo, Im not sure if hes still selling them though.
delslow45
Apr 3, 2011 07:14 PM
Dc295kid
Nov 18, 2008 12:54 AM
dan89crxsi
Feb 24, 2004 10:43 AM
turbochic
May 6, 2003 02:15 PM
ASHY-ELBOW
Oct 30, 2002 09:41 AM
