What HeadGasket for a Drag III setup on a 98GSR?
1 Post
Re: What HeadGasket for a Drag III setup on a 98GSR? (98GSR-T)
well, anything that will lower your compression. You can go with an inline pro 2mm headgasket which will bring you down to 9:1.
I am using a cometic which is a a lot cheaper. Mine is .043" and it brings me down to 9.6:1. I cant give you any input on it since I just installed it and my car is still down waiting for the tranny to be swapped.
How many pounds were you boosting? How do you know its blown?
[Modified by intekragsr, 10:41 PM 3/9/2003]
Re: What HeadGasket for a Drag III setup on a 98GSR? (intekragsr)
I was running 6psi...Coolant in the oil...Mositure where the head hits the block...Not 100% sure, but close
eg:R
08-08-2008 02:58 PM
bodydropranger
12-27-2002 07:01 AM
