who's tried a msd 3bar map with hondata
New User
Re: who's tried a msd 3bar map with hondata (DLB1994)
it works fine, I do it all the time. If it doesn't work, you don't have it wired correctly, because its exactly the same as the 3 bar Hondata sells and the one that GM sells.
1 Post
Re: who's tried a msd 3bar map with hondata (VaporTrail)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail »</TD></TR><TR><TD CLASS="quote">it works fine, I do it all the time. If it doesn't work, you don't have it wired correctly, because its exactly the same as the 3 bar Hondata sells and the one that GM sells.</TD></TR></TABLE>
Is it part # MSD-2313 (via summitracing), or PN 23131 (via http://www.msdignition.com/200...ensor ). One is on back roder, and one is not
really? the MSD i had did not work with hondata...
i also figured it was a wiring problem, but when i used the one I ordered straight from GM, it worked...
so for me, the MSD did not work...
New User
Re: who's tried a msd 3bar map with hondata (Ruckus138)
then the MSD that you had was broken. It's a GM map sensor. It's no different than any other GM map sensor of the same specifications. I use these map sensors on a daily basis
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VaporTrail »</TD></TR><TR><TD CLASS="quote">then the MSD that you had was broken. It's a GM map sensor. It's no different than any other GM map sensor of the same specifications. I use these map sensors on a daily basis</TD></TR></TABLE>
no you're broken
no you're broken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruckus138 »</TD></TR><TR><TD CLASS="quote">
no you're broken</TD></TR></TABLE>
wow, smart guy!
wow, smart guy!
New User
wow, that was weak. Am I supposed to come back with something like "your mom" or something? I forgot what it was like to be 10 years old.
wow, that was weak. Am I supposed to come back with something like "your mom" or something? I forgot what it was like to be 10 years old.</TD></TR></TABLE>
babahahahahahahaha
babahahahahahahaha
MSD and GM 3 bar look Identical to me. I have both at home (MSD is for a friends car). We compared them last night, and they even have the SAME connector! same size, everything. Gonna hook them up this week and compare voltages on them, but i'm pretty sure they are the same part.
yes it was a joke. your Honda-Tech sarcasm detector must be on the fritz. get a new one.
1 Post
Re: who's tried a msd 3bar map with hondata (servion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">
Is it part # MSD-2313 (via summitracing), or PN 23131 (via http://www.msdignition.com/200...ensor ). One is on back roder, and one is not</TD></TR></TABLE>
anyone?
anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion »</TD></TR><TR><TD CLASS="quote">It's originally a buick grand national sensor, right? Will any turbo grand national sensor work?</TD></TR></TABLE>
Nope Buick GN is only a 2 Bar, the only GM car to use the 3 bar was the 1989 20th Anniversary Turbo Trans Am. Also John my dad can beat up your dad and leave Ruckus138 alone you big bully!
New User
yes it was a joke. your Honda-Tech sarcasm detector must be on the fritz. get a new one.</TD></TR></TABLE>
Sarcasm is not a readily supported language of any browser at this time.
i'm in no immediate need of a 3 bar MAP sensor, but i am curious to know what part # to look for in the future for when i buy one. i've heard before that the MSD and GM are the same. but i've been told that the Hondata MAP is different than the first 2 (not saying it's true, just what i heard in the past).
so can anyone provide an exact part # for the GM 3 bar MAP sensor so i can check with my local auto supply shop for one?
thanks
thanks
Re: who's tried a msd 3bar map with hondata (sweet)
Actually I think there was a run of defective MSD 3 bars at one time or another.....thats probably why this thread is posted.
Re: who's tried a msd 3bar map with hondata (93LSivic)
sorry bout the sarcasm before but...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic »</TD></TR><TR><TD CLASS="quote">Actually I think there was a run of defective MSD 3 bars at one time or another.....thats probably why this thread is posted.</TD></TR></TABLE>
anyway to tell if you have a defective one?(other than trying it) by just looking at it?
