could this be a sign of engine running lean???
Old Mar 9, 2003 | 03:21 PM
Boosted Gsr Hatch's Avatar
Default could this be a sign of engine running lean???
i have a drag gen 3 kit on a b18c1 with rc 310's and the car fells like its making good power untill 5000 rpm then it seems to loose a signifigant amount of power.My cel is on because one of my 02 sensor wires has be severd. would this be a lean mix issue.also my car studers a little under partial acceleration but i already adjusted the gap down. let me know what you guys think.
Old Mar 9, 2003 | 03:40 PM
rjardy's Avatar
Default Re: could this be a sign of engine running lean??? (Boosted Gsr Hatch)
that could be allot of things, are you sure that you are only throwing the one code because no o2 reading? Yes a loss of power can be traced to running lean, along with a list of other things.
Rob
Old Mar 9, 2003 | 03:43 PM
Tinker219's Avatar
this is called limp mode...you are seeing no fuel increase, hence lean...I wouldnt take it too far above idle until the CEL is gone...
my 2 cents...
Old Mar 9, 2003 | 06:48 PM
rioninja's Avatar
Default Re: could this be a sign of engine running lean??? (Tinker219)
an O2 sensor problem will not put the car in "limp" mode, just FYI. But i agree that you should take care of that before doing anything else.
XxfatlacexX808
May 10, 2013 05:57 AM
livedew12
Jan 10, 2012 08:58 PM
antwonskee
Apr 26, 2009 10:08 PM
98IntegraLSNonVtec
Jul 31, 2006 01:46 PM
DumpedSi
Aug 21, 2003 05:57 PM
