can i weld pipe to my oil pan?
instead of buying a flange,can i just weld a 5/8's piece of pipe to the pan,its a can from a crx,using a cheapo welder with no gas?
Re: can i weld pipe to my oil pan? (civictypenos)
technically, yes.. but welding dissimilar metals is hard and you really have to be carefull not to burn through the pan...
if you just have a cheapo welder I would hazard to guess you are more likely to ruin your pan than to be successful...
brazing (witha torch) is the proper way to do this
EJ1 wilcox
11
02-16-2005 08:57 AM
