Hondata dataloggers - what is datalog errors?
Old Mar 7, 2003 | 05:50 AM
Doodoo's Avatar
Default Hondata dataloggers - what is datalog errors?
As I am new to the system I am still battling small bugs. Otherwise its badass!!
If I datalog for awhile(1.5hrs +) my Logger starts showing errs/sec. They start low at 1-2err/sec then it will hit the tolerance of 5err/s and drop the connection. I am using the Keyspan Serial->USB, I suggest getting this piece.
I have J12 removed as well. Its just strange it only happens after datalogging for long periods of time.
Thanks for any suggestions.
Old Mar 7, 2003 | 07:52 AM
MikeMAN's Avatar
Default Re: Hondata dataloggers - what is datalog errors? (Doodoo)
where does it save the datalog to? out of space?
mike
Old Mar 7, 2003 | 09:29 AM
Brian_92GSR's Avatar
New User
It's probably the USB-serial device, I've heard nothing good about them, and have had nothing but problems when using them with my AEM EMS. I ended up getting a PCMCIA-serial adapter and it has worked flawlessly. It is a bit more expansive though, around $100.
Old Mar 7, 2003 | 10:08 AM
Doodoo's Avatar
Default Re: Hondata dataloggers - what is datalog errors? (Brian_92GSR)
The USB->serial adapter is working 100% better than straight to the serial port. I shouldn't be running out of storage(512RAM). Thanks.
Old Mar 7, 2003 | 10:15 AM
MikeMAN's Avatar
RAM = memory, not storage hehe. i just wasn't sure if the datalogged stuff was saved on your hard drive (gigabytes) or on a chip in the hondata.
Thanks,
mike
Old Mar 7, 2003 | 12:31 PM
Doodoo's Avatar
Default Re: Hondata dataloggers - what is datalog errors? (MikeMAN)
Oh well in that case its a 30GB HDD with 22GB left. So I am ok, unless there is a TEMP file that Logger writes to that can be increased....
Old Mar 7, 2003 | 01:04 PM
sgT's Avatar
sgT
WHY are you logging for 1.5HRS at a time? no need for that lol
Old Mar 7, 2003 | 01:07 PM
MikeMAN's Avatar
i bet your power saving is kicking in probably turning off/powering down some of the peripherals after a certain period.
go into power managemnt in the control panel and make sure everything is always set to turn off : Never
hope we can help ya, but man..not like u have huge problems datalogging for 1.5 hrs hehe
good luck!,
mike
Old Mar 7, 2003 | 01:36 PM
Doodoo's Avatar
Yeah its not a huge problem but it does get annoying. All my power savers are off, no hibernate, nothing.
Anyone used the 1 microfarad Capacitors? Are those to improve datalogging at all? I know they are not necessary. Thanks MikeMan!!
hatchback freek
Nov 1, 2012 06:36 PM
beast59
Aug 29, 2006 06:26 PM
*Boostwerks*
Sep 6, 2004 05:47 AM
98civicguy
Apr 8, 2003 07:24 PM
Civicdrgrcr
Jul 3, 2002 12:03 AM
