Fuel needed upgrades to run 9lbs
Old Mar 9, 2003 | 07:08 PM
shadow103rd's Avatar
Default Fuel needed upgrades to run 9lbs
Okay, I need to know what is the smallest about of money I can spend because im on a budget. whats necessary to the fuel system to upgrade to safely run 9 lbs. And also how long will stock clutch and axles last.
Thanks yo,
96 civic ex
bone stock, will be boosted very very soon though
Old Mar 9, 2003 | 07:16 PM
greddyturboGSR's Avatar
Default Re: Fuel needed upgrades to run 9lbs (shadow103rd)
My set-up is pretty mild so my stock clutch actually lasted me about 6 months before I replaced it with ACT stage 2. haven't had any axle issue yet either.
DeepSi's Avatar
you should atleast get a fuel pump. maybe fuel injectors depending on current setup.
stock clutch will not last that long.
axles should be alright depending on your driving habits.
johnisenglish's Avatar
SMC500 and DSM Injectors - you can do the whole setup for $200 (which is about how much an FMU setup is going to run you) and still have a little room to grow
Old Mar 9, 2003 | 07:24 PM
Default Re: Fuel needed upgrades to run 9lbs (johnisenglish)
one of my friends told me that all I will need is a boost dependent FPR, and maybe a fuel pump, can this be ran safely.
Silvertc
Jan 10, 2010 09:05 PM
4LugR
Nov 15, 2008 02:26 PM
uNF$@#!
Aug 6, 2002 07:45 PM
MugenSi00
Dec 2, 2001 10:55 AM
