Need answers on this MAP sensor issue
Old Mar 9, 2003 | 06:50 PM
Joecube25's Avatar
Default Need answers on this MAP sensor issue
Hello all, new to the site. I had found it very informative and really cool. My questions are the following and I need straigh answers, I searched on this site before posting and did not find the answer I was looking for, so here goes.
1) Can I change my map sensor from the factory 1 bar to a 3 bar using the stock ecu and my S-AFC?
2) If the answer to 1 is yes, what can I expect from running this type of sensor?(i.e. idle lean or rich? )
3) If the answer is no, what about that missing link high tech check valve, how many psi's of boost is that good for? Any one order one from the website?
*I have a 92 civic dx, JE pistons, 8.5 cr, pauter rods. In short, short done everything I had to do to help my motor take the abuse but by doing so ran outta cash to buy an stand alone system, just to give you all who answer an idea.
Old Mar 9, 2003 | 07:38 PM
MiraiZ's Avatar
Default Re: Need answers on this MAP sensor issue (Joecube25)
1. no, at least without some kind of piggy back to compensate. EDIT:S-AFC (not sure)
2. as above
3. Missing link won't help in this case...all it does is stops the check engine light from lighting when the ECU sees boost. Your stock Honda MAP sensor is good for 11psi either way.
Nothing high tech about the missing link (LOL)...its a chunk of metal!
[Modified by MiraiZ, 1:40 PM 3/10/2003]
Old Mar 9, 2003 | 07:56 PM
98Psi ITR's Avatar
Default Re: Need answers on this MAP sensor issue (MiraiZ)
actually missing link stops map sensor from seeing boost altogether. You can run as much boost as you want theoretically. I would not advise it. I have run over 15psi on such a setup...not the way to go.
Old Mar 14, 2003 | 04:13 AM
Joecube25's Avatar
Default Thanks Guys for clearing that up
I guess I'll just be running low boost until I can get my hands on an aftermarket ECU. But again, thanks
Old Mar 14, 2003 | 04:27 AM
Tinker219's Avatar
Default Re: Thanks Guys for clearing that up (Joecube25)
Yep, believe it or not, a built bottom end will pop if something goes wrong too....
better safe than sorry...
Standalone=
B18Sleeper
Oct 26, 2005 12:52 PM
l2yanE
Oct 2, 2005 10:15 AM
teggreen4
May 13, 2005 02:12 PM
gsrt2c
Jun 8, 2003 05:35 AM
abraunb16
Jun 26, 2002 06:56 PM
