2 quick easy turbo questions
Old Mar 8, 2003 | 10:25 AM
boosted_zc's Avatar
Default 2 quick easy turbo questions
What size lines for oil feed and return, i believe feed is -3 so return should be larger if i'm correct so no pressure is built up. And the best place to tap for and water cooled turbo, feed and return. Thanks
Old Mar 8, 2003 | 10:26 AM
MikeMAN's Avatar
Default Re: 2 quick easy turbo questions (boosted_zc)
Feed:
43" of -3AN stainless steel braided lines with hose ends installed
1- 1/8" BSPT to 1/8" NPT adapter ( to go to your block to eliminate cracking and leaking)
1- 1/8" NPT brass tee
1- 1/8" NPT to -3AN adapter straight
1- 1/8" NPT to -3AN adapter 90deg
Return:
1-1.5ft of -10 stainless steel braided lines
2- -10AN of anodized blue/red hose ends straight
1- 1/2" to -10AN adapter
1- -10AN steel weld on fitting for your oil pan
Old Mar 8, 2003 | 04:27 PM
boosted_zc's Avatar
Default Re: 2 quick easy turbo questions (MikeMAN)
Great that's one part, now i need the water part.
PA MATT
Aug 5, 2004 09:00 AM
igo4bmx
May 1, 2003 01:08 PM
DoriDoriboii
Mar 10, 2003 09:47 PM
jdmtegxsi
Jan 20, 2003 03:36 PM
Snafu-Si
Jul 2, 2002 07:58 AM
