fuel pressure and pump questions
Old Mar 6, 2003 | 07:50 PM
vha27's Avatar
Default fuel pressure and pump questions
so i did the vafc hack and im still running real rich, im as low as -45 and getting too low map input cells, cell 13
so here the thing im def running way too rich, now i got the walbro pump and the dsm 450's, so i figure get an aem adjustable fpr and turn it down
now heres the question
to do the vafc hack correctly its recommened u use the bigger injectors and pump, my fuel pressure as of now, vacuum unhooked is 48 psi, stock injectors and stock pump the reading accorind to helms is 38 to i think 44
so fuel pressure increased with the pump, now im wondering did i need the bigger fuel pump in the first place since i need a lower fuel pressure, my psi would be what the factory said with bigger injectors, im so confused, all i know is that im real rich, ne advice on how much i should turn down my fuel pressure since i cant lean it out enough with my vafc? oh apexi turbo on a y8
thanks,
chris
Old Mar 6, 2003 | 08:16 PM
DefiantGSR's Avatar
Default Re: fuel pressure and pump questions (vha27)
lose the pump. Its making you run rich.
Old Mar 7, 2003 | 06:14 AM
vha27's Avatar
Default Re: fuel pressure and pump questions (DefiantGSR)
why even put 450cc's on then, if fuel pressure is the same as stcok, wont i get the same amount of fuel in?
Old Mar 7, 2003 | 06:31 AM
Tony Starks's Avatar
No, you be fine. Like he said. Ditch the pump. Or of course you can buy a FPR. I run the same hack set up and I used my adjustable FPR to drop the pressure. I STILL run rich.
Old Mar 7, 2003 | 12:19 PM
gtcali's Avatar
Default Re: fuel pressure and pump questions (Tony Starks)
I've been debating if I'm going to put my inline fuel pump in. Is it recommended to not run a fuel pump with a VAFC??
Old Mar 7, 2003 | 01:40 PM
MikeMAN's Avatar
even though the fuel pressure is the same, the injectors will flow more..
mike
Old Mar 7, 2003 | 02:12 PM
home_made_turbo's Avatar
Default Re: fuel pressure and pump questions (MikeMAN)
I just put the hack on my 2000si and i had the same problem. What i did to fix it was get a AEM FPR and lower the pressure at idle to 29PSI (with the vacuum line connected & with a Walbro 255). In order to get this low of a fuel pressure you need to use the gold insert that comes with the AEM FPR. Therefore at 0 vacuum I am at 39PSI with a 1:1 rise rate per pound of boost (45PSI at 6lbs of boost). With my 1000RPM set to -37 it idles just like stock, however I did have one instance where it was hard to start. Other than that I have not dynoed it yet but I am planning to next week. Also I took 2 degrees of timing out at the distributor which may have made a difference.
TurboSpoolinInside
Jul 24, 2011 06:06 PM
RTW DC2R
Sep 27, 2005 01:46 PM
B16CRXT
Aug 29, 2004 11:06 PM
g_man80
Sep 14, 2003 10:47 AM
TypeR1558
May 25, 2003 01:29 PM
