Almost done, need little help though.
Heres the thing. Everything is put together, i pull a relay so that it doesnt crank over, but it starts up, just to see if the oil like will spit out oil to my turbo. I took the wire off the turbo and put it into a can. I start it several times, i get out, and i see no oil. Whats up with that?? Do I need to actually have the engine run to have oil squirt out of there? what do you think is wrong??
u need the engine to crank, just not start. just start the car, although the turbine will be moving...its not like ur gunna be boosting. Just shut it off as soon as u see oil come.
mike
mike
The engine wasnt rebuilt, it was just a turbo install. I see some oil underneath the car now, i can see where its coming from though but it may be the reason that im not gettin pressure for the oil to go through the line. Damnit this is frustrating.
i would check where u t'd off the block in the back, it seems like that is where its leaking...use teflon tape if you haven't already
mike
mike
arsenaldragster
Dec 21, 2006 05:54 AM
2000vsm
Aug 29, 2003 07:06 PM
