oil leak?????????????????why??????
Old May 24, 2003 | 09:37 PM
gsrcivict's Avatar
Default oil leak?????????????????why??????
I have a 98 gsr with a t3/04 E turbo kit on it and have had nothing but problems with it. I can not seem to stop a oil leak coming form the return line off the turbo. At first I had a hose with clamps on it and it leaked, so I put a braided hose with earls fittings on it and thought I was done. NOPE! the damn fitting that goes into the flange on the turbo is leaking! wtf? Im so tired of oil leaks Im ready to sell the whole car! I put a 10an hose with all the earls fittings on it and still have this leak. Tomorrow I will put a lil silicone on the threads and see if that stops the leak. Just wanted to see if anyone else had had this problem. THANX for all your help fellas!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 26, 2003 | 01:36 PM
gsrcivict's Avatar
Default Re: oil leak?????????????????why?????? (gsrcivict)
anybody????????????????
Old May 26, 2003 | 02:16 PM
Poop111444's Avatar
If you can see the oil leak.........that should narrow it down (duh i guess)
If its leaking at the hose end (earls fitting), maybe you did not assemble the fitting correctly? Remember, you gotta put these babies in a vice and crimp it on good. I first assembled braided lines and i didn't know what i was doing and it leaked like a mother. I then found the CORRECT way to assemble the lines and it works beautiful
Old May 26, 2003 | 02:19 PM
Jared's Avatar
Default Re: oil leak?????????????????why?????? (si_mekanik)
and use teflon tape on your threads as well
Old May 26, 2003 | 03:44 PM
Adriano's Avatar
Default Re: oil leak?????????????????why?????? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">use teflon tape </TD></TR></TABLE>
Old May 26, 2003 | 04:23 PM
Burke's Avatar
Banned
Default Re: oil leak?????????????????why?????? (brryder)
what size earl fitting should i put into my t3/t4 oil feed line?? also i have never dealt with these, but i got like 3 feet of stainless line for free so i am gonna give it a shot. is there a proper technique to it or is there a site that tell me how to do it? one more thing, anyone know what and where i can get the adapter off the block. sorry for all the questions, but this is my first turbo build up. thanks
ps - sorry for stealing your thread
Old May 27, 2003 | 10:16 AM
gsrcivict's Avatar
I did put teflon on one side of it and it leaks from there not from the side that does not have teflon. doesnt oil eat teflon tape?
Old May 28, 2003 | 10:11 AM
gsrcivict's Avatar
Old May 28, 2003 | 10:16 AM
bluebullet's Avatar
Default Re: oil leak?????????????????why?????? (Burke)
the adapter for the block is a 1/8 bspt to npt fitting, you can get it at mcmastercarr for like $5
Old May 28, 2003 | 11:04 AM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">and use teflon tape on your threads as well</TD></TR></TABLE>
Actually, a guy at a hose and fitting assembly business told me to not use teflon tape...this makes sense because it is a compression fitting and doesn't make the seal with the threads. It makes the seal with the tapered part of the fitting and the ferule (or do Earl's not use these? I use Aeroquip).
I would suggest tightening the fitting until you think you might break it, you have to crush the ferule to some extent to get a seal...assuming earl's work like Aeroquip. Also, it might be leaking from the plate that the fitting attaches too, the turbo gets hot and could have melted whatever you used to seal it, if it wasn't a high-temp gasket. Even RTV will burn up.
Old May 28, 2003 | 11:29 AM
PM-Performance's Avatar
Default Re: oil leak?????????????????why?????? (ion_four)
teflon paste will cure all
Old May 28, 2003 | 12:02 PM
gsrcivict's Avatar
teflon.......paste? whats that? where can I get that? I have XRP fitting but they are the same as Earls. on the side without tefdlon tape it is not leaking but around the side that does have it is where the flangwe and everything else is so Im not sure if its leaking from the flange or what. I think its leaking from the compressor side housing cuz it wobbles alot like if you didnt tighten your lugnuts and the tire would wobble. Im tired of oil leaking everywhere!!!!!!!!!!
I did use a 450 degree rtv silicon for the gasket. where can I get a high temp gasket from?
Old May 28, 2003 | 12:58 PM
Scott - 93HB Si's Avatar
I use teflon paste aswell.....no leaks for me.
Old May 28, 2003 | 02:52 PM
gsrcivict's Avatar
Default Re: oil leak?????????????????why?????? (Scott - 93HB Si)
ok thats 2 people that say they use teflon "paste" what is that? where can I get it? what about a gasket for the flange on the oil return? can I make a gasket for that and outta what? thanx for the help fellas!!!!!!!!!!!!!!!!!
I still need a downpipe for a 5 bolt housing on a drag 2 kit t3/4 B
Old May 28, 2003 | 02:55 PM
raene's Avatar
Teflon paste is like gooey teflon tape; teflon tape in a bottle . I'm not sure where to buy it but your local autoparts store is a good start.
Old May 29, 2003 | 08:28 AM
gsrcivict's Avatar
Default Re: oil leak?????????????????why?????? (raene)
so this teflon paste is for high temp? can it be used for a gasket or only on threads? thanx
Gabe
Old May 29, 2003 | 08:58 AM
ash.zero's Avatar
make sure you didnt overtorque the 1/2 npt thread from return line assembly to flange...i cracked my flange and that leaked like a *****...
before that, i forgot to put teflon tape on it, so it was leaking...so i tried to tighten it and i cracked that flange into 2...
so...
#1 - use teflon tape
#2 - don't overtorque
#3 - make sure your flange is tight and that it has gasket on it
good luck...
Old May 29, 2003 | 09:35 AM
gsrcivict's Avatar
so does anyone know of another common gasket that I can buy and make one for the oil return flange? or can I use the teflon paste? thanx
Gabe
Old May 29, 2003 | 09:41 AM
turbochic's Avatar
I have heard from many, and also read that you are not supposed to use teflon tape or paste on the oil fittings. In the instructions for my turbo, it said use teflon tape on all the fittings EXCEPT any oil lines.
My experience with teflon paste wasnt that great, I used it on a NOS kit that I used to have and it didnt seal worth crap, then I used the tape and it worked completely.
I got my teflon paste at the hardware store in the plumbing section.
but imo I wouldnt use either. but hey the choice is yours
VSM EXtasy
Oct 6, 2009 12:19 AM
shortstopNE
Apr 4, 2009 09:39 AM
mafioso102
May 14, 2003 06:23 PM
jdmtegxsi
Jan 20, 2003 03:36 PM
shadowdawn
Oct 7, 2002 10:33 AM
